Interesting proposal...
Old Sep 14, 2002 | 09:47 PM
Speed PHreak's Avatar
Default Interesting proposal...
This is an exploded view of the bottom-end on a 2.1L Prelude AKA -- B21A.
Notice the 5-row girdle. Anyways, the point is that plenty of poeple know about the GSR/ITR gridle swap. What about this girdle, has anyone adapted this to say the bottom-end of an LS/B20? In the diagram the main caps all look flat just as the GSR/ITR bottom-end. Not really sure if this would be any better than stock on a GSR/ITR. Though on the d-series don't they have full length girdle? I mean if the d-series that have such weaker compenents than the b-series, and run a full row girdle.....would running one a b-series be a benefit.
Granted I think the B21A did have like a 6000-ish redline and about 1.37:1 rod stroke ratio...I'm sureit need all the help I could get to stablize the bottom-end.
Here is the page for the picture on Hondaautomotiveparts.com . Part number 009.
Old Sep 14, 2002 | 09:54 PM
Jared's Avatar
Default Re: Interesting proposal... (Speed PHreak)
assuming its b series, it should work because the bore and main centers should be the same. never thought about that.
Old Sep 14, 2002 | 10:00 PM
Default Re: Interesting proposal... (Jared)
Yeah, it's a B-series.....just the red-headed stepchild of the series.
Old Sep 15, 2002 | 07:26 AM
non-VTEC's Avatar
it might fit onto the main caps with some moidifications.............but will it clear the oil pan? windage tray? what oil pick up would you use??
things to consider.................
Old Sep 15, 2002 | 07:42 AM
HXMan's Avatar
Hmmm...looks like a good idea. Someone needs to pick one up from a junkyard and give it a try!
The D series does have a full length girdle...that thing is a beefy lookin girdle too.
orezbus12
Transmission & Drivetrain
15
Mar 9, 2023 09:01 PM
Zimbob
Sep 3, 2008 11:30 PM
Mushvroom
Jan 18, 2006 10:22 PM
AllmotorJunkie
Mar 17, 2003 09:08 PM
Speed PHreak
Sep 15, 2002 10:23 AM
