Classic Hondas All Pre-1988 Hondas.
87 Civic Si Help..
Old Jul 4, 2010 | 05:05 PM
Alchemist Dragon's Avatar
Icon3 87 Civic Si Help..
I was trying down the road today and stopped to get gas.. I pulled out and the shifter was working fine... When I got to the exit I needed, it suddenly wouldn't let me gear down.. Now it is hard to get into gear.. Once you're going it's fine but still doesn't want to gear down.. Thinking it's a loose clutch.. Anyone have any ideas?
Old Jul 4, 2010 | 06:42 PM
E-AT_me's Avatar
Default Re: 87 Civic Si Help..
maybe a clutch cable?
Old Jul 4, 2010 | 07:27 PM
Checked the cable and it seems the clutch still works somewhat...
Old Jul 4, 2010 | 07:45 PM
E-AT_me's Avatar
try adjusting it at all?
Old Jul 5, 2010 | 03:49 PM
I played with the adjustments today... I started and drove it a bit then it worked fine... After a little while it started not wanting to go into gear again..
Old Jul 5, 2010 | 04:52 PM
E-AT_me's Avatar
huh. i think it may have something to do with the cable then. make sure the clutch pedal itself did not snap.
Old Jul 5, 2010 | 05:44 PM
OCdude31990's Avatar
i had the same problem with my 90 hatch. it turned out that the fluid level in the trans was very low. i had to double clutch for every gear. check the fluid level. if the gears aint properly lubricated, the gears wont mesh nicely
Old Jul 18, 2010 | 04:00 PM
Gabe87CRX's Avatar
I had the same problem... clutch disc springs came out... be prepared to redo the clutch.
DANINE101
Transmission & Drivetrain
Mar 13, 2010 10:04 AM
dumada9
Jan 23, 2010 03:27 AM
hurleyint1386
14
Jan 19, 2006 03:09 PM
trianglegreg
Nov 12, 2005 10:58 AM
senpai
Apr 30, 2002 01:15 PM
