Honda S2000 Honda S2000
How many RPM can a stock AP2 head withstand???
Old Jul 4, 2010 | 07:41 AM
JUSTINTHECOASTI's Avatar
Default How many RPM can a stock AP2 head withstand???
what the title says, pretty much...thanks
Old Jul 4, 2010 | 07:48 AM
kevinnuh's Avatar
Default Re: How many RPM can a stock AP2 head withstand???
What are you trying to say here? isn't it Governed at 8.5k for AP2?
Old Jul 4, 2010 | 08:02 AM
I know that, I look down at my dash everyday, Im asking if anyone has gone pass 8.5k...prepare for a long story...ok I had a f20c but blew the head, swapped in a complete f22c, buddy bent 2 valves, purchased another f22c from honda, rebuilt the f22c with bent valves with all stock parts, so how I have a f20c block and a f22c head in my garage...hahahahaha...I want to know if the f20c block and the f22c head see higher than 9.2k safely...and if no what needs to be done outside of the engine management stuff...plan is to put this engine into a completely gutted rolling body S
Old Jul 4, 2010 | 10:38 AM
egvtec's Avatar
To more accurately answer your question you will need to know that the cams in any f series motor stop making power about 200 rpm before the rev limiter anyhow, so any revving past 9k will just be useless without a more agressive cam profile and a valve train to support the cams. But I have seen many ap2 owners rev to 9 on a f22 stock head so I'd say you will be ok up to 9k revving any stock f series valvetrain
Old Jul 4, 2010 | 10:51 AM
yes that too I know, power drops off right around 8.3k for the f20c, maybe this will help yall understand, I know stock cams wont carry power past 8.3k, but with the valves, springs, retainers, seats, etc. hold up? how many rpm can they take til they fail?
Old Jul 4, 2010 | 11:38 AM
egvtec's Avatar
Anything over 9k there are no guarantees your valves will most likeley begin to float on the stock springs
Old Jul 4, 2010 | 11:58 AM
10250rpm on the F20c is when valves start tapping the piston, so I was thinking it might have changed for the f22c...
Old Jul 4, 2010 | 11:59 AM
there is also the option od de-stroking it...not my cup of tea
Old Jul 4, 2010 | 12:07 PM
reason for doing this is I want to keep motor na for track, and I'm looking for a way to stay in vtec but at a higher point...Ive seen an S rev to 12k in PR and my cousin in savannah said all you need done is headwork so I was just asking questions,I know more power will come with cams blah blah blah,lighter valves work as well...
Old Jul 4, 2010 | 07:14 PM
egvtec's Avatar
Try it out if you can afford another motor if it let's go. You might be sucessful with it.
Old Jul 8, 2010 | 04:13 PM
10sec4door's Avatar
Do it the correct way. you dont need head work (as in pnp) valvetrain and cams and have fun.
Old Jul 9, 2010 | 05:34 AM
ExVtec's Avatar
You ALSO need to consider the bottom end. Spinning a motor that fast has more to do than the head, although that is still important.
I spun my to 8500 pretty often, but never hit 9k, although thats the next tune. For me it's about extending my already short gears for boost and trapping a little higher.
Old Jul 9, 2010 | 11:12 PM
ABCVTEC's Avatar
There's an AP1 revving to 12k, and a handful of AP2s revving to 9.5k. It can be done but with the proper machine work and parts.
- Fully balanced rotating assembly
- Lightened rods, pistons, and flywheel (Crower Maxi-Light rods and CP pistons)
- Titanium retainers and dual valve springs
- Ported intake manifold and throttle body
- A GOOD pair of camshafts
- A really good machine shop and assembler
In the end you're looking at a fat bill and a motor that is very high maintenance. Most titanium retainers need to be replaced every 10k miles and you'll want to pick bearings that suit the build as well and those will wear faster also. You'll also want to stay on top of valve adjustments because anything getting too lose is going to cause a grenaded motor. A part of that list that often gets overlooked is the intake manifold. On an AP2 build I saw that damn IM was a huge bottleneck. The heads are really good on this motor as stock so minimal work needs done there.
Old Jul 11, 2010 | 08:27 AM
sweet thank you for the information, I knew it could be done but I couldnt really put my finger on the "how to do" part again thank you all
Txdragon
Engine Machining & Assembly
15
Jul 27, 2018 10:06 AM
projectef
Jul 13, 2006 07:41 AM
b18bturbo
Aug 17, 2005 06:32 AM
BuiltTurboCoupe
Sep 25, 2004 06:35 PM
H22CIVIC
Oct 9, 2001 09:06 PM
