LSVtec timing belt cover?
Old Jul 3, 2010 | 11:36 AM
1sloEM1's Avatar
Default LSVtec timing belt cover?
I'm about to finish my motor and was curious what timing belt cover I need to run. This maybe a stupid question, but are all B series timing belt covers the same? Is there a difference in the water pump hole diameter between the 19tooth LS and 22 tooth Vtec?
I'm running a B18b1 with a pr3 head
any and all help would be greatly appreciated, thanks
Old Jul 3, 2010 | 12:36 PM
92bseries's Avatar
Default Re: LSVtec timing belt cover?
u need one for an ls
Old Jul 3, 2010 | 01:19 PM
thumper64's Avatar
the lower cover would have to be LS and the top would have to be B16. idk if they'll match up or not.
Old Jul 5, 2010 | 10:30 AM
1sloEM1's Avatar
well that works out well then, I'm not running an upper cover so that won't be a problem. thanks for the help guys! I appreciate it.
Old Jul 5, 2010 | 10:43 AM
HAMOTORSPORTS's Avatar
You can use any integra 96 and newer lower cover as they are all the same on these years, the upper outer will not line up perfect, but pretty close with a gsr upper outer. If you use a 95 or older lower cover, you will not find an upper that lines up at all.
EthanolSTi
Sep 14, 2012 10:07 AM
92integraVTECgsr
May 25, 2008 07:04 AM
92'si
Feb 19, 2006 12:58 PM
foam
Dec 26, 2005 10:23 AM
85mm LS VTEC
Aug 4, 2004 02:18 PM
