Help me!!
Old Sep 14, 2002 | 08:13 PM
BoostedTypeR's Avatar
Default Help me!!
ok here is my deal. i just got done rebuilding my TypeR i put it back together and went to start it and it started but i had no throttle response, so i tried to pump the gas pedal hoping for some response, it worked but the only way i can get my car to stay idling is if i pump the gas pedal constantly. I also noticed i had some oil build up on my head gasket. so i took the head off. one the head was off i noticed that only the #1 cylinder had been combusting. the other 3 were still shinny and new. i reassemble dthe motor once again and did all the tests i could think of and my car still wont idle properly. I checked ffor spark i have spark, i checke dteh compression it is godo and i also checked to make sure the injectors were working. everything seems to be working fine but with no success the car still wont idle correctly and it still has a oil buildup around teh head gasket. someone plz help me i have run out of ideas. thank you...
Old Sep 14, 2002 | 08:55 PM
salbaje's Avatar
Default Re: Help me!! (BoostedTypeR)
check timing. are there sparks from all cylinders??
Old Sep 15, 2002 | 08:09 PM
Default Re: Help me!! (salbaje)
yeah there is...
v8killaz
Jun 23, 2011 03:22 PM
94eg5squadMD
13
Feb 14, 2009 01:32 PM
taimysho0
Feb 7, 2009 04:01 PM
BoostedTypeR
Sep 16, 2002 05:30 AM
