Transmission & Drivetrain Gearboxes, Differentials, Clutches
transmission whine and grind
Old Jul 2, 2010 | 03:17 AM
Gaspari's Avatar
Default transmission whine and grind
Just put new gsr transmission in... with type r lsd. When I accellerate it whines and when I let go of the gas in gear it sounds like it is grinding. Checked fluid everything was fine. Any ideas??
Old Jul 2, 2010 | 09:01 AM
David @ Synchrotech's Avatar
Default Re: transmission whine and grind
It sounds like a bad bearing in the transmission.
Old Jul 6, 2010 | 07:21 PM
sh!ft's Avatar
Who the fack changed my title?!
yes dave i believe you are correct. but what would cause the grind?
op, is it a grind like a gear grind when changing gears or a different type of grind. where did you get this trans from....
b18c1ej8
Nov 29, 2010 03:26 PM
ryanj1025
Jan 23, 2008 01:11 PM
White_EK49
Nov 3, 2005 05:08 PM
Chiclets
May 5, 2003 07:07 AM
