can this be done
Old May 2, 2003 | 01:25 AM
Chiclets's Avatar
Default can this be done
can I take an integra type r tranny and replace a grinding third gear with either a gsr gear or a b16 gear I don't know if this is possible but I might consider it just cuz the type r has lsd
Old May 2, 2003 | 01:48 AM
NA gs-R 05 C
Guest
Posts: n/a
Default Re: can this be done (bluedemon)
u can, but that third gear would be longer or shorter dependin on the gear ratio of the gear u put in, gsr will definitely be a lil longer though.
Modified by NA gs-R 05 C at 11:05 AM 5/2/2003
Old May 2, 2003 | 03:34 AM
.RJ's Avatar
.RJ
if its grinding, its not the gear, its the synchro. Gears are always meshed together.
Old May 2, 2003 | 05:36 AM
2qwik2nv's Avatar
How much milage and what year is your car? I know it's a common issue with the Integra trannys. Mine is going into Acura next week. This service is being covered under warranty. Mine is an '01 with 50000 KM on it.
Old May 2, 2003 | 05:56 AM
Dave-ROR's Avatar
Default Re: can this be done (.RJ)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by .RJ &raquo;</TD></TR><TR><TD CLASS="quote">if its grinding, its not the gear, its the synchro. Gears are always meshed together.</TD></TR></TABLE>
what he said.
Old May 2, 2003 | 07:20 AM
TypeR 01 886's Avatar
Default Re: can this be done (dawhiteboy)
So that grinding sound is not the sound of the transmission gears grinding? I though this was so. The grinding sound is of the synchro?
I think you mean the synchro needs to be replaced but the tranny gears do grind when the synchro was bad. Please correct me if im wrong (wich wouldn't supprise me)
Old May 2, 2003 | 08:07 PM
Chiclets's Avatar
Default Re: can this be done (TypeR 01 886)
so the question is know are the synchros interchangeble?
Old May 5, 2003 | 07:07 AM
Dave-ROR's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by TypeR 01 886 &raquo;</TD></TR><TR><TD CLASS="quote">So that grinding sound is not the sound of the transmission gears grinding? I though this was so. The grinding sound is of the synchro?
I think you mean the synchro needs to be replaced but the tranny gears do grind when the synchro was bad. Please correct me if im wrong (wich wouldn't supprise me) </TD></TR></TABLE>
the gears are on the mainshaft and countershafts and they do not move. Not only that, but they are interlocked with their corresponding gear on the other shaft. They do NOT grind. The syncros are what grinds.
q16racer
Transmission & Drivetrain
Apr 19, 2011 01:48 PM
EK-Chris
Jan 13, 2005 09:35 PM
Jake
13
Mar 11, 2004 11:33 AM
zbower7
Feb 21, 2004 03:31 AM
