Car Wont Start PLEASE HELP!!!
Old Jul 1, 2010 | 04:12 PM
JDMb18c1HATCH's Avatar
Icon6 Car Wont Start PLEASE HELP!!!
ok here's the long story short I got this car in a million pieces and rebuilt the whole damn thing from bumper to bumber. Its a 92 civic hatch with a b18c1 swap its fully built but now I cant get it to start. Im getting fuel and fire and sometimes it acts like it wants to start but it never does.
the ECU I know for sure is a p27 chipped obd1 as far as the dizzy im not sure but its got 2 plugs so i think its obd1 as well.
please help ive spent 9 months and about 18-20K on this build so far and im loosing interest I need to be running ASAP
what can it be
Old Jul 1, 2010 | 04:23 PM
jerryegk24's Avatar
Default Re: Car Wont Start PLEASE HELP!!!
Bad battery or starter.
Former User's Avatar
Is gas injected into the cylinders?
Is spark bright white at all four plugs?
Are the plug wires installed in the correct firing order on the distributor cap?
Is the mechanical timing correct?
Old Jul 1, 2010 | 04:33 PM
YES YES YES AND YES
It does have AEM tru time timing gear on it and greddy timing belt with ngk platnum plugs and vision motor works 10.2 spiral core plugs.
It was doing the same thing last week and I undid the fuel rail and noticed the injectors were only dripping fuel so I replaced them today with new ones 310cc and tried it and the injectors worked fine.
but before the changes if I sprayed starter fluid in the cold air intake it would run. i tried it after the new injectors and nothing
Old Jul 1, 2010 | 04:37 PM
ek4_b16a's Avatar
checked all your grounds?
Old Jul 1, 2010 | 04:49 PM
Yea all the grounds are good. It cranks and sometimes acts like it wants to start but just wont roll over and run.
I do know that I dont have the knock sensor but was told it is not needed in the 95 teg b18c1 or if it was chipped and it is both.
I also dont have a crank position sensor dont see a spot for it and it was not on the block when I got it.
anything else that will def keep it from running?
Also I didn't do the wiring it was already wired when I got the car but I did plug everything where it goes during the rebuild of the motor and car
Old Jul 1, 2010 | 05:43 PM
Are the cylinders now flooded with fuel?
Have you compression tested the cylinders?
Old Jul 3, 2010 | 07:42 AM
the cylinders are not flooding with fuel and yes they are all getting good compression as far I as Know.
it will crank and crank and crank and every once in a while act like its going to start a little like its trying to fire off but then wont and continues to do nothing but crank
o and another thing the spark plugs are getting spark but its an orange'ish color spark its not bright white like stated above. BUT! wouldnt it still fire off as long as its getting a spark?
Old Jul 3, 2010 | 06:46 PM
GOT IT RUNNING THANKS FOR ALL THE INPUT.
It was the throttle position sensor was not adjusted right. I losend it up played with it for a min and it cranked right up WOOOOOOOOOOOOOO WHOOOOOOOOOOOOO!
Old Jul 3, 2010 | 07:26 PM
If spark is orange, then the coil is on its way out.
Sturg
Oct 27, 2009 12:04 AM
avargas28
Apr 15, 2009 05:32 PM
smoovekriminal
Aug 17, 2007 09:55 PM
MATiC
Jan 27, 2007 08:28 AM
Tr0LL
Aug 15, 2001 03:51 AM
