is this head blown!?
Old Jul 1, 2010 | 03:20 AM
frokido's Avatar
Default is this head blown!?
Hey, I have a 91 Su with d16 vtec engine in it and recently timing jumped and the Damn valves were smashed. I am buying a "rebuilt" head and I was wonering if there were many ways. To tell if. It had any problems before buying it then swapping and crankng. BTW he said it still has heat tab... but can't u just put a new one onif the other one melts? Lol. Thanks
Old Jul 1, 2010 | 05:40 AM
~sp33~'s Avatar
EFB055
Default Re: is this head blown!?
The phrase 'blown head' usually means headgasket. It's not very often you 'blow' a head.
I'd make sure that the valves seat correctly i guess. Check for scoring on the cams, check for warpage... That's all the advice i can give sorry.
Old Jul 1, 2010 | 07:13 AM
frokido's Avatar
K that is good advice considering I'm a beginner car enthusiast. Thanks and if anyone else has any mire advice I would greatly appreciate it.
Old Jul 1, 2010 | 09:29 AM
casprghst68's Avatar
check in the combustion chambers for small cracks between the valves also. if any doubt have a machine shop take a look at it
Old Jul 1, 2010 | 11:57 AM
24TEN's Avatar
PHANTOM MENACE
Here's a quick trick to tell if the valve seats are sealing:
Clean off the combustion chambers as best as you can. Take the head (with manifolds off) and spray brake cleaner into the ports with the head on it's side making sure the corresponding valves are in their closed position. Look at the corresponding valves and see if they are leaking. If they are dry, you have a good seal. If they get a little damp, you're so so but still functional. If they are damp and the brake fluid is spreading you have a slight sealing issue that needs to be addressed. If the fluid just pours out, that cylinder will have very low or even zero compression.
Also inspect for deck straightness with an engineering/machinist straight edge if possible.
Old Jul 1, 2010 | 12:36 PM
BiG ChOr!Zo's Avatar
aint heat tabs used by jdm engine importers to tell if a engine has overheated if you try to get a warranty...!!!
civilsantana
May 19, 2016 09:03 PM
Pbanto
May 3, 2007 12:14 AM
Boostedb20EH2
Mar 25, 2007 05:56 PM
inspyral
Mar 14, 2003 02:57 PM
redman223
Jan 10, 2003 01:57 PM
