h22A4 obd2 to obd1 conversion
i have searched the forums and after digging through the garbage i am not looking anymore. can someone please tell me what i need to do to swap the H22A4 into a 1994 Honda prelude which had the h22 in it. i have the ecu for the 94 but not the engine harness just need to know what need to be done to the wiring harness and if the 94 trans will mount up. pleas don't answer unless you know what it all needs to be done. thank you
ok simplicity will be best can i put the original obd1 harness on the h22a4. what do i need to change over injectors dizzy what else need this car running before the weekend please i need help new to Honda
i was just wondering if i could use the motor harnes and not swap anything but now i am going to build my own harness to do the wire tuck all i need is an old harness that no one wants for the conectors unless someone has a h22 obd1 harness for sale
Choy
Feb 25, 2010 03:07 PM
