Need Help W/ NX Wet System ASAP
I have a NX wet system, and i don't know how to wire the provided relay to the Solenoids. The relay has red, black, green and white wires and the solenoids have 2 wires each. Let me know how to install this.! Thanx!!
Yes, both solenoids have two wires each. Use one from each as a positive, and one from each as a negative. Wire the positives and negatives together.
Follow the diagram that came with the kit as for which colors go to what. I don't remember off the top of my head. Check the solenoids for proper operation before you give them any fuel or N20.
Good luck.
Good luck.
Black = 12 volt +
Green = Goes to one wire on N20 and Fuel Solenoid, should be two wires.
White = Ground
Also when doing the N20/Fuel Solenoid, you will ground the extra wire each.
Reason I know is cause I a NX system w/ all the xtras!!
If you have any other questions let me know..
Hope this helps ya!
[Modified by Midwestrider, 5:47 AM 9/15/2002]
ESP.net
Jan 15, 2021 07:51 AM
elmalouno
Audio / Security / Video
Dec 7, 2004 01:36 PM
bcphatchback
Nov 17, 2004 07:02 AM
