VTEC pressure sensor setting check engine light
my car continues to set the CEL light i believe its code 23 and thats the VTEC pressure sensor but only sets the light in upper rpms in 3rd gear if launching. anyh thoughts?
well as far as i know the pump is fine. its a JDM swap so there is nothing saying that it is perfect by anymeans. it only sets the light in 3rd gear right around when it hits VTEC.
it was code 22 at first, VTEC oil pressure sensor, then it set 21 which i believe was the VTEC solenoid. maybe need to replace the solenoid but just didnt know if this was a common issue or an inexpensive repair
I'm assuming there may be something up with your oil. If it's not throwing it the minute you hit VTEC in any gear, it's an oil problem, namely an oil pressure problem in third gear.
so possibly oil pump, i only like 1500 into my oil change and its 10-30 maybe switch to 5-30?
can it be removed and cleaned without replacing any seals or gaskets?
Vtecme92
Jul 10, 2006 06:27 PM
UpstateCivic
May 10, 2003 05:18 PM
