Which External Coil is best to use.
Old Jun 29, 2010 | 06:04 PM
Quickridez_3's Avatar
Icon2 Which External Coil is best to use.
Currently i have a stock ignition set up on my car stock wires, internal coil and dizzy. It was good for 600whp but this year im going to go with a precision 6765 so i want to make sure i have a strong spark. I was thinking bout doing a m and w pro 10 or a msd digital 6. some people been telling me that all i need is an external coil and ill be fine to max out that turbo.
so whats the coil to run ive been hearing that i need an HVC2 for my car but right now i have a new in the box ProPower HVC coil PN 8251 It was going to be used on another race car in conjunction with a 7AL3 but no longer going to use that set up. Do you guys know if this can be used with stock ignition even though it says right on the coil to be used with MSD 7 SERIES IGNITIONS ONLY?
whats the difference in the two and what do you guys recommend I just dont want to end up changing the coil twice.
Old Jun 29, 2010 | 06:21 PM
HamiltonRex's Avatar
Default Re: Which External Coil is best to use.
if you want a less expensive cdi, you could look into the dynatec arc2. Its pretty common/popular in the dsm world, and its just straight badass. Not to mention, cheap.
Old Jun 29, 2010 | 06:42 PM
how much are they? well i have the hvc one right ahead of me and i can get it cheap but i know alot of hondas are using the hvc2 and im not sure why. iknow the hvc2 work with the msd 6 and the other works on the 7 but im running neither so i dont know if it matters
Old Jun 29, 2010 | 09:21 PM
cloviskilla's Avatar
hvc 2 blue is the best the hvc 2 red will burn up most boxes except the 7 series boxes. unless u have m@m ignition money??
Old Jun 29, 2010 | 09:29 PM
cloneme311's Avatar
i am running just my hvc 8252 coil but i seem to be burning up ignitors so i am gonna use a digital 6 plus box with my setup. but it works great! just my 2 cents
Old Jun 29, 2010 | 09:59 PM
ive seen people do good with msd blasters but ive tried 4 and they always break up at high rpm??? i tuned a 550 hp with a old in cap accel coil it worked flawless.
Old Jun 29, 2010 | 10:38 PM
sc34dx's Avatar
i would use a ps92 from crane cams...best external coil out there in my opinion...we use them on our 600 and 800whp cars...no break up at all....
Old Jun 29, 2010 | 10:59 PM
jdm inc's Avatar
I was running the msd digital 6 with the blue hvcII coil then switch to the M&W pro 10 with the cranes cam ps92 coil.
Old Jun 30, 2010 | 01:18 AM
Zer0_SpeedWorks's Avatar
Ps92 gets my vote
Old Jun 30, 2010 | 07:53 AM
narfdanarf's Avatar
ps92 here
Old Jul 1, 2010 | 11:18 AM
DeLucia's Avatar
ps92
Old Jul 1, 2010 | 07:56 PM
will that work fine with a stock ignition or do i still need to run with a msd or m and w box? is the crane ps92 better then the msd hvc2 or are people running it because its a cheaper alternative?
Old Jul 1, 2010 | 08:30 PM
BlakeJ53's Avatar
in for info
Old Jul 1, 2010 | 10:24 PM
narfdanarf's Avatar
Pretty sure you have to run a cdi box with it. It works great and it's $100 cheaper than the hvc II.
Old Jul 2, 2010 | 02:09 PM
seanc520's Avatar
from what i read on msd's site the blaster ss coil puts out 40,000 v's and the blaster2 cylinder coil puts out 45 and so does the hvc2 so there for the blaster2 is the same right? will the ps92 coil work with my msd sci?
stinker504
Apr 26, 2007 04:16 AM
_oemek_
Aug 16, 2004 04:16 PM
SebAyatollah
Aug 19, 2003 06:57 AM
B_1_8_hatch
Aug 4, 2003 03:13 PM
Duck Sauce
Nov 16, 2001 08:19 PM
