97 acura el b16 injector issue
Old Jun 29, 2010 | 11:13 AM
xsellxoutx's Avatar
Default 97 acura el b16 injector issue
ok so ive had this car running for the past 2 years no issues it was hesitating and backfiring for a few days then died on the way home from work. i replaced the plugs, wires, cap, rotor, fuel filter, cleaned the little filters in the injectors, and tried another fuel pressure regulator. i noticed the fuel isnt returning (the return line was bone dry and lots of pressure in the fuel rail) i just tried some noid lights on my injectors and none of them are getting power... is there a fuse or relay im missing??? unless the stock obd2 b1 ecu took a **** on me... ideas?
Old Jun 29, 2010 | 11:48 AM
Jdmglenn's Avatar
Default Re: 97 acura el b16 injector issue
did you try pulling CEL
Old Jun 29, 2010 | 01:31 PM
xsellxoutx's Avatar
code 20 electronic load detector....
Old Jun 29, 2010 | 11:16 PM
xsellxoutx's Avatar
Old Jun 30, 2010 | 10:32 AM
xsellxoutx's Avatar
ANYBODY?
Old Jun 30, 2010 | 10:36 AM
xsellxoutx's Avatar
my ecu looks ok i looked inside doesnt seem burned up... and all the ecu i have access to are obd1... fail
Old Jul 2, 2010 | 05:33 PM
xsellxoutx's Avatar
Old Jul 2, 2010 | 08:17 PM
asifbychance's Avatar
sock in fuel pump dirty? when i swapped mine. we hit the fuel and cut fuel volume. did run or srape over anything? try to flow your fuel pump.
Old Jul 4, 2010 | 09:11 PM
xsellxoutx's Avatar
i havent checked but yes i scrape pulling into my spot at work. but i checked my injector wiring w/ noid lights and my injectors arent getting power... im sure my pump works cause my fpr shot off when i swapped it out. but the return line was bone dry
Old Jul 4, 2010 | 09:15 PM
b18cKoupe's Avatar
the return line should never be bone dry, the stock system delivers plenty of fuel and it should constantly be being returned to the tank via the return line.
Old Jul 14, 2010 | 11:51 AM
xsellxoutx's Avatar
Icon2 Re: 97 acura el b16 injector issue
i tried 2 diffrent stock fpr... i cleaned my injector filters, but im not getting power to the injectors when i checked them w/ noid lights... what makes the injectors pulse? i gotta havr a ****ed off ground or simething...
Old Jul 20, 2010 | 11:04 PM
xsellxoutx's Avatar
anybody....
EKcpe00
Mar 29, 2013 05:30 PM
88HATCH(:
Jun 20, 2010 07:40 PM
Canuk_SiR
Nov 10, 2009 11:35 AM
Sean DM
Jun 12, 2007 01:43 PM
phatrick2332
Nov 16, 2004 06:06 AM
