Leak down test help
Old Jun 29, 2010 | 08:50 AM
sloassSi's Avatar
Default Leak down test help
I have a b16 and want to do a leak down test. I was told I need to find TDC for each cylinder when doing the test. I am not 100% sure how to do this or the test. Does anyone have instructions on how to do this?
Thanks.
Old Jun 29, 2010 | 09:18 AM
sloassSi's Avatar
Default Re: Leak down test help
t
Old Jun 29, 2010 | 09:31 AM
KevinBrown's Avatar
http://www.c-speedracing.com/howto/l...n/leakdown.php
And use this how to for lining up TDC for each cylinder...
http://www.c-speedracing.com/howto/v...alveadjust.php
Old Jun 29, 2010 | 10:19 AM
fungus mungus's Avatar
Take the spark plug out of the cylinder you want to test, put a long object inside the spark plug hole...it will be resting on top of the piston. Now turn the crank by hand and watch the long object rise up until it's at it's highest point. Hook up your pressure gauges to the cylinder and test...if you hear rushing air, you're on the exhaust stroke and not the compression stroke and you'll need to turn the crank again until the piston rises to the top again. Repeat and note your readings.
fm
Old Jun 29, 2010 | 12:36 PM
sloassSi's Avatar
Thanks guys.
flipldls
Nov 28, 2010 04:41 PM
1badteg
Jul 16, 2007 02:00 PM
rasinhell
Feb 22, 2005 11:06 PM
jeremy.
Sep 26, 2003 09:03 AM
lazy bum shaughn
Jan 28, 2003 07:55 PM
