Fuel filter?
How much should one cost? Ive noticed my fuel milage has been hurting, so i replaced the spark plugs, spark plug wires, etc, the only thing I neglected was the fuel filter, could this be the cause?
Where is it?
[Modified by up-youRs, 8:14 AM 9/15/2002]
how many miles do you have on your car?? if it is less then 60k dont even bother...
i change it every 15k just because i put random gas into the car.
No matter what gas you get there will always be **** on the bottom of your gas tank. You dont want to run your car out of gas or bring it to a low level because then it sucks all that **** up and goes into your fuel filter. You won't/shouldn't notice this problem all that much unless it is REALLY clogged.
Replacing the fuel filter should be done every 30k miles. Pretty easy thing to change out.
You dont want to run your car out of gas or bring it to a low level because then it sucks all that **** up and goes into your fuel filter. :
You dont't want to run your tank low because that will allow the furl pump to operate with poor lubrication and cooling. It will shorten the life of your fuel pump.
Jayk00CivicEx
Mar 29, 2012 10:49 PM
