Rear end clunk/pop
Old Jun 28, 2010 | 02:29 PM
Doom325's Avatar
Default Rear end clunk/pop
I've had this problem for a while but it seems to be getting worse. It happens when braking and when going over bumps so I assumed it was going to be my endlinks b/c I have a tanabe swaybar but I pulled it off today and took a quick drive to narrow it down to the bar but the sound is still there! What would generally cause this? Tomorrow i'm going to go buy a ball joint seperator to pull off my rear ucas to inspect my ball joints and replace my 5 year old obx camber kit with oem anchor bolts. What else could cause this headache?
Old Jun 28, 2010 | 05:38 PM
MikeTheGreek's Avatar
Default Re: Rear end clunk/pop
I just installed my Progress sway bar and my car is lowered so it hits the control arm I feel your pain!!! im looking at buying because they are a little narrower. If it still makes the noise when you take your sway bar off then you probably are bottoming out. shocks could be gone. do you have a lowering kit?
Old Jun 28, 2010 | 06:32 PM
Doom325's Avatar
I am lowered on some neuspeed sports/kyb gr2s but I just swapped those struts in a few thousand miles ago. I don't think they are blown. If they were I wouldn't care anyway. I just ordered some tein basic coilovers
Old Jun 28, 2010 | 06:35 PM
wraith646's Avatar
Check the upper strut mount. It can sometime give a hiddenoise when it is soft.
Old Jun 28, 2010 | 09:43 PM
gstrudler's Avatar
There's a TSB at least on the 5th gen's for this. I believe it's the shock collar, but not sure if that still applies when you've replaced the shocks already.
Old Jun 29, 2010 | 03:34 AM
Doom325's Avatar
I forgot to mention that this is a 4th gen lude.
Old Jun 29, 2010 | 01:05 PM
Doom325's Avatar
I'm in the middle of changing those anchor bolts out and of course on of the bolts is bent and will not come out. It spins freely but it wont budge. Damn!
Old Jun 29, 2010 | 05:37 PM
prelude_h22vtec's Avatar
when mine started doing the pop/clunk in the rear it turned out to be the aftermarket Camber-adjustable anchor bolts for the upper control arm. The bolt had sheared right off.
Old Jun 29, 2010 | 06:10 PM
Doom325's Avatar
That was my second thought behind the swaybar links. I just removed my 5yo obx camber kit for new OEM anchor bolts. Hopefully my alignment wont be too far off!
Old Jul 1, 2010 | 04:22 PM
Doom325's Avatar
Looks like it is going to be the rear upper ball joints. I'm going to replace them and i'll let you guys know what the verdict was. I'm going with honda ucas from majestic honda because their prices can't be beat.
Old Jul 1, 2010 | 06:01 PM
I use majestic alot. The prices aren't anything to brag about, but they are a little cheaper than my local dealer when you absolutely need OEM parts.
Old Jul 2, 2010 | 04:50 AM
Doom325's Avatar
They are alot cheaper than my local dealer. Saved me 100 bucks a month ago when I replaced my front ucas.
Old Aug 14, 2010 | 05:49 AM
ShoofIsLudin's Avatar
old thread i know....majestic has great prices...but when I ordered water pipe o-rings and a few other little o-rings/gaskets it cost me more for shipping than the parts themselves.... would've been the same price for me had I gone to my local dealer
Coopa B18c5
Feb 1, 2013 09:39 PM
soon2bdropped
10
Feb 27, 2011 11:26 AM
grandtheftlunchbox
23
Nov 4, 2008 08:06 PM
97_BB6
Mar 4, 2007 02:17 PM
jdmstreethatch
Aug 28, 2004 08:15 AM
