92 4dr wont start no voltage at the fuel pump
My civic had been starting hard (taking a while to start) it died on me two weeks ago as if the key had been turned off I changed the plus and wires that week and cleaned the points on the distributor cap.
Now it died on the way home from work and will not restart I changed the main relay on advice from a friend. I still won't start. It isn't getting any voltage at the fuel pump, if I jump the relay from the power into the plug to the fuel pump, the pump will turn on but the car won't start still. The relay buzzes like its supposed to when you turn it on, but still dosen't send power to the fuel pump.
I'm out of ideas at this point.
Did I get a bad relay?
Is there something else not letting the relay work?
any help would be awesome
Does the CEL stay on? Any CEL codes?
In addition to the fuel pump failing to prime, do you also lack spark at the plugs?
Have you checked whether fuse 31, 24, or 18 is blown?
Have you cleaned and tightened the ground wire attached to the thermostat housing?
RecklessEJ
15
Sep 18, 2011 03:56 PM
ThatRHDstatus
Aug 8, 2010 08:05 AM
ej84dr
Jun 16, 2010 05:20 AM
civic08
Mar 14, 2010 09:26 AM
