95' civic ignition problem
Old Jun 27, 2010 | 12:11 AM
white_gsr's Avatar
Icon2 95' civic ignition problem
i own a 95 ej1 just recently the key ignition cylinder whatever its called anyway well i put the key in the other day and i turned it on let go of the key and it turned off, So i tried it again this i held the key in the on position and it stayed on but as soon i let go off the key is turned off so i know that its gotta do with something in the ignition. So i bought a new one i just have no clue how to install it.
could you guys help me out?
Old Jun 27, 2010 | 10:54 PM
white_gsr's Avatar
Default Re: 95' civic ignition problem
bump, anyone know anything? i could really use some help.
Old Jun 27, 2010 | 11:40 PM
delsolproblems's Avatar
You take out the screws holding the plastic covers onto the steering column. You drill off the heads of the shear head bolts holding the lock cylinder on using, I believe a 3/16 bit. Use a punch to make a dimple in the center of the screw head first. Install the new one and hand tighten the bolts. Put the key in and make sure everything works properly. Use a wrench to tighten the new bolts until their heads break off.
Old Jun 27, 2010 | 11:42 PM
white_gsr's Avatar
thanks man, really appreciate it.
robcivic559
Feb 27, 2014 10:19 AM
rasta420high
Mar 27, 2013 05:14 PM
travbrack
Apr 12, 2012 04:58 PM
viera
Mar 22, 2010 09:06 PM
plikit
Jan 2, 2006 10:24 AM
