Help, car very low idle and run's rough!!!
Old Jun 26, 2010 | 10:36 AM
jdmkid209's Avatar
Default Help, car very low idle and run's rough!!!
I have a 97 EK civic and it idle's almost at zero for awhile now I adjusted the idle couple times already and it STILL goes back almost to zero to idle. When its cold it idle's rough it feels like the car is gonna die out. E-mail me at j3poy209@aim.com if you can help out thanks..
Old Jun 26, 2010 | 11:46 AM
delsolproblems's Avatar
Default Re: Help, car very low idle and run's rough!!!
Borrow a compression tester from a parts store and check your compression.
Old Aug 17, 2010 | 05:38 PM
vinnyme4's Avatar
if you have a compression issue say in one cylinder and not the rest it would be well worth the money to get a cylinder leak down tester, if you have access to a air compressor that is
Old Aug 18, 2010 | 06:56 AM
a94civicex's Avatar
Also how many miles is on the motor? May just need a tune up. Fuel Pump, Fuel Filter, Injectors, Spark Plugs, Wires, Distributor, Rotor Button, the whole works. If you have done that get a timing gun on it, it may be a couple of teeth off on the timing. Go from there.
SI_frankenstein
May 15, 2008 02:42 PM
v8killaz
Mar 19, 2008 06:54 PM
brolli
Sep 1, 2005 08:03 AM
ethan9273
May 6, 2003 03:31 PM
