jdm h22 swap issues help!
Old Jun 25, 2010 | 06:37 PM
jdmludesi's Avatar
Icon3 jdm h22 swap issues help!
so i jsut swapped a jdm h22a into my 93 si
i went over every connector before i went to start it, i installed the p13 that came with it, went to start it and nothing, well its a crank no start
i checked to fuel line and nothing is coming out, no fuel pressure
does anyone have any ideas as to why im not getting fuel, i even put the orginal ecu from the h23 to see if for some reason it worked and still no fuel
is there anything that typically causes this, possibly even low battery voltage, could that cause the fuel pump to not get enough voltage and deliver fuel? im really confused if anyone has any ideas id greatly appreciate it, im trying to get this started before i head off to college
Old Jun 25, 2010 | 09:32 PM
thiskid0001's Avatar
Default Re: jdm h22 swap issues help!
check if your fuel pump turns on when you turn the key to on position you should be able to hear it from the tank if not check fuses
turboteg7
Dec 21, 2008 11:12 AM
preludepimpin8668
Sep 4, 2007 01:38 PM
office888
Mar 18, 2007 07:28 PM
TexasluvsHondas
Nov 21, 2006 07:37 PM
hwnstyle21
Sep 8, 2002 02:14 AM
