Transmission & Drivetrain Gearboxes, Differentials, Clutches
type r trans diff?
Old Jun 25, 2010 | 06:54 AM
mmsj1's Avatar
Default type r trans diff?
installed this type r tranny in my buddy's car and when you make a turn while giving it gas it makes a horrible clanking noise like the axles are or the diff was gonna snap. whats that piece inside the diff? never seen it before.
Old Jun 26, 2010 | 10:54 AM
mmsj1's Avatar
Default Re: type r trans diff?
any body know what that is??
Old Jun 26, 2010 | 11:40 AM
Mr. smith's Avatar
looks like a spool
Old Jun 26, 2010 | 02:19 PM
mmsj1's Avatar
that's what i was thinking but he ordered the tranny online from one of those jdm distributors. it's suppose to be stock. don't think they came that way from the factory. it came with the starter, rear bracket, slave cylinder, fork/bearing, clutch and flywheel. casing doesn't look like it's ever been opened.
Old Jun 26, 2010 | 02:21 PM
David @ Synchrotech's Avatar
This is not an OEM ITR LSD. It is an aftermarket LSD with belleville washers. These are what you see in the center of the axle holes. The noise you are hearing could be the CV joints or could be from the gears in the LSD. It is common on less expensive (Lower quality) LSDs for these washers and internal gears break causing this noise. Bottom line is that you will probably need a new LSD.
Old Jun 26, 2010 | 05:12 PM
mmsj1's Avatar
i was hoping you'd chime in, but not with that kind of info about the diff being bad, hahah. oh well, not really my problem but i'll let my friend know what's going on with his tranny. thanks for the input.
laziebun
16
Sep 9, 2008 08:49 PM
vtecb20coupe
Apr 17, 2006 07:58 AM
chambersef8
Apr 1, 2004 06:03 PM
JDM97R
11
Jan 23, 2004 01:17 PM
