clutch problems on swapped hatch! help!
Old Jun 25, 2010 | 06:37 AM
b93hatch18's Avatar
Default clutch problems on swapped hatch! help!
i have a 93 hatch with a 98 integra ls motor and trans. i started having occasional clutch slippage only after i was driving for awile. when the car was cold i couldnt even make it slip wich led me to belive it was hydrolics. i changed the slave and the master i have no leaks in any of the lines. evry time it slips i can bleed the system and itll go away for a weeks worth of driving wich for me is about 450 miles lol. the way i bled it was at the slave just like brakes is this correct? or is their a trick to it? or is my clutch prob just bad?
Old Jun 25, 2010 | 09:02 AM
jdm_head's Avatar
Default Re: clutch problems on swapped hatch! help!
check the fork if its bent and does it make any noises ??
Old Jun 25, 2010 | 12:29 PM
b93hatch18's Avatar
fork looks to be in good shape i also have been bleading it just by pumping the clutch having them hold it down and cracking the screw ive been reading diff ways to blead it like using the clear tube on the nipple rinning into a container with fluid in it so no air gets by anyone else know any good ways to do it
Old Jun 25, 2010 | 12:36 PM
Nichelson_Performance's Avatar
Bleeding it like brakes is fine that's how I do mine at first then I gravity bleed it
You could have a problem with the pressure plate being weak
b93hatch18
Sep 22, 2010 10:50 AM
integragsssr
Feb 6, 2009 08:54 PM
kazman
Feb 2, 2007 12:28 PM
EgGriff
Jan 9, 2006 08:40 AM
iwhichisme
Nov 24, 2002 05:47 AM
