where do you put in the transmission oil?
near where the passenger side axel in the tranny there is a bolt its half way up the diff think 17mm, take it out, put a small hose on the end of the funnel and fill untill oil start coming out, i use 10w30 pretty sure this is what honda recommends
your all wrong..... it goes where the 55 mm nut is on the rear diff...lol, dam i think the kid now knows instead of confusing him by different holes to stick it in, next he will think he needs to bend over and fill up yours... hahahaha question/ topic closed. lol
But anywho, that green plug sensor thing on top of the tranny i put in two quarts of 10w30 Penzoil Platinum. It took it all. And I stripped the fill bolt on the bottom... its neeen removed from there. But now I have a problem that my gears wont go into gear now...
You really did'nt pay attention did you ? If you did you would be driving your car right now and have NO problems ! Come on man I am a LADY and yes I have done this many times. Next time if there is one use ROYAL PURPLE MTF is good **** !!
