Help I bought a car with a missing Part, What goes here?!
Old Jun 24, 2010 | 05:06 PM
95-delsol-broke's Avatar
Icon2 Help I bought a car with a missing Part, What goes here?!
Can someone tell me what electric module is suppose to go here?
Thanks in advance!
Old Jun 24, 2010 | 05:16 PM
mattliston's Avatar
Default Re: Help I bought a car with a missing Part, What goes here?!
is the gray with white inside plug 4 pins?
check under your car for a secondary O2 sensor. if one is hooked up, they simply have a different OBD2 engien harness. 96-98 is OBD2a and 99-00 is OBD2b. one ahs teh second O2 in the engine harness, teh other has it in the dash/interior harness.
Extra plug, no worries
green plug looks like a automatic solenoid plug
is your car originally an automatic?
run the vin number on www.myhondapartsstore.com and find out.
or go to a dealership.
Old Jun 24, 2010 | 05:44 PM
One has a blue and black wire, the other one has just a green wire.
The car is currently an automatic
Old Jun 24, 2010 | 05:50 PM
mattliston's Avatar
look under the distributor. single wire sensors are there. perhaps its a coolant sensor or an oil switch plug.
oil switch is next to the oil filter in teh back of teh block
Old Jun 24, 2010 | 05:54 PM
would any of those prevent the car from having spark?
Old Jun 24, 2010 | 06:26 PM
mattliston's Avatar
doubt it
dont buy a broken car lol
Old Jun 24, 2010 | 06:47 PM
This car is a 95 odb1 , the green wire has 4 pins a black and blue, grey connector just has a ground wire. What other modules are tied to the distributor wiring harness?
Old Jun 24, 2010 | 06:49 PM
EJeff8's Avatar
Isn't the green one for your VTEC solenoid?
Old Jun 24, 2010 | 07:28 PM
EG'SUS's Avatar
It looks like the ones going into my VTEC solenoid
Old Jun 24, 2010 | 10:48 PM
92turbohatch430's Avatar
u know when i looked at it i thought the same thing. That it was ur VTEC solenoid, check it out.
Old Jun 24, 2010 | 11:14 PM
Jdmglenn's Avatar
Vtec and reverse light?
Old Jun 25, 2010 | 01:35 AM
HondaPartsHero's Avatar
Technical Hero
That is for VTEC pressure switch on the right and VTEC solenoid on the left (in this picture). If there is no where to plug it in right by the distributor than you don't have a VTEC solenoid.
Old Jun 25, 2010 | 04:37 AM
apexi_rsx's Avatar
x2 vtec and pressure switch for a vtec solenoid. the car must not have one now but did before
Old Jun 25, 2010 | 07:24 AM
Targa250R's Avatar
be professional
The picture in the original post definitely shows a non-VTEC cylinder head.
Old Jun 25, 2010 | 08:50 AM
EJeff8's Avatar
^^. You don't have VTEC, so those wires are useless to you. If your car isn't running, those are not the problem.
EF'GSRrr91
Jan 28, 2015 12:31 PM
sive
Jul 16, 2013 08:29 AM
bassysingh
Oct 3, 2011 04:58 PM
ChrisRicketts
Nov 3, 2007 01:20 PM
headhunter
15
May 31, 2006 03:38 PM
