newbie buying a turbo car Help..
Old Jun 24, 2010 | 02:43 PM
gixxer508's Avatar
Default newbie buying a turbo car Help..
Ok Im planning to buy a 99-00 civic si that is boost. Im a newb which no nothing about turbo. How do I know there is nothing wrong with the motor?? What question should I ask?? How do I know the turbo setup is correct?? How do I know everything is running good?? lol I know its alot but thanks.
Old Jun 24, 2010 | 02:47 PM
azandford's Avatar
Default Re: newbie buying a turbo car Help..
first perform a compression test the psi should be within 5-10 of each other
find out if its tuned and what it is tuned on
also see if if the motor has been built or if its stock.... see if he has receipts for the internals
buying a used turbo car is a big risk....i bought one used and the motor went out 2 months later
Old Jun 25, 2010 | 06:26 AM
jdm_head's Avatar
check for oil around motor and parts listen 2 idle make sure its right hear out for any taps internaly check 4 smoke no black no blue or white smoke check brand of turbo make sure its a gd brand (e-bay turbos suk) i usally by the gd stuff 4my car like they say u get wat u pay 4
Old Jun 25, 2010 | 08:31 AM
scketch's Avatar
^^^THis
+if you have a friend that knows about them I would definitely take him with you. Another thing you should consider is that boosted cars require more maintenance, can you do this? If something breaks could you figure it out? ALso will this be your dd? Just keep thinking smart and don't make a bad decision
Old Jun 25, 2010 | 08:38 AM
cleansi's Avatar
x2 compression check
just remember its impossible to find a em1 that has not been stolen or wrecked at least once
Old Jun 25, 2010 | 09:07 AM
jdm_head's Avatar
i got 1 and its jus sittin in my garage lol
Old Jun 25, 2010 | 09:56 AM
Hill4589's Avatar
You would be better off buying a stock car since you have very minimal knowledge of cars.
Old Jun 26, 2010 | 06:08 AM
gixxer508's Avatar
Thanks guys for your help. I think Im going to pass on this turbo car. Its to complicated. Its true having minimal understanding good get you into alot of trouble. On to the next one.
Old Jun 26, 2010 | 06:17 AM
fsg231's Avatar
^ good choice
Old Jun 26, 2010 | 08:32 AM
tmatkej1's Avatar
on top of that make sure things such as heating and a/c work as well...had a friend with an IS300 boosted and the a/c didn't work, ended up trying to use it once and messed up his motor
jdmcivic2fast
Aug 6, 2012 08:38 PM
DBKIDD16
Jul 17, 2007 03:16 AM
riceball777
Jun 26, 2006 06:22 PM
obsidianG35
May 22, 2002 07:35 AM
