throwing code 45
Old Sep 14, 2002 | 10:18 AM
cjohnson_2's Avatar
Default throwing code 45
I posted this in another forum but no one is helping me so i thought id post it here and see what people think.
MY CEL came on this morning and i scanned it and i have a code 45 which means my car is running to lean...
What could be the problem with this? i just changed the fuel filter a few weeks ago. Is it possible my fuel pump is about to go out?
How can i fix this problem??
Old Sep 14, 2002 | 12:58 PM
B19CivicHB's Avatar
Default Re: throwing code 45 (cjohnson_2)
Could be a faulty O2 sensor. If it is reading rich, it will lean the engine out. Just an idea.
-Nick-
Old Sep 15, 2002 | 07:56 AM
cjohnson_2's Avatar
anyone know?
Old Sep 15, 2002 | 07:28 PM
ITR#132's Avatar
A code 45 could be too lean or too rich.
Check you fuel pressure regulator.
Old Oct 16, 2002 | 08:58 AM
StolenSi's Avatar
Default Re: throwing code 45 (ITR#132)
I can't seem to get rid of this code either. What if my fuel pressure is to spec: 47~52 (B18C5)? I'm wondering if the OEM Civic fuel pump I'm running is too small for the R motor. Does that make any sense?
Old Oct 16, 2002 | 11:31 AM
577HondaPrelude's Avatar
Default Re: throwing code 45 (StolenSi)
could be any of the following:
Fule pressure to high or to low
Fule injectors are the wrong type (too big or too small)
Fule injortor is clogged
Fule filter is clogged
O2 senser is bad
Anyway, just some ideas of could be your prob...
[Modified by 57STS, 3:32 PM 10/16/2002]
Old Oct 16, 2002 | 02:37 PM
Chiovnidca's Avatar
Default Re: throwing code 45 (57STS)
O2 senser is bad
A couple other things I have seen cause that code:
Valves adjusted too tight.
Leaking purge control valve.
adez1313
Apr 22, 2013 09:56 AM
brnyrdcmndo
Jun 1, 2005 06:37 PM
PhilStubbs
Jan 22, 2005 11:20 AM
95hatchfire
Jan 12, 2005 10:52 AM
OBDI JEDI
May 7, 2003 05:06 PM
