Hatch latch isnt working on the R
Old Jun 23, 2010 | 03:55 PM
TypeRod's Avatar
Default Hatch latch isnt working on the R
Has anyone ran into this problem? When I move the latch over to open, I don't hear the motor release the lock to open. But when I use the key it will open, but I have to turn the key all the way to the right. Im not familiar with the locking mechanism on the hatch, is there a switch or motor to replace for my situation? Thanks in advance!
Old Jun 23, 2010 | 04:00 PM
baysic r's Avatar
Default Re: Hatch latch isnt working on the R
mine just went out too....all you hear is the motor being used right.........mine is the actuator....it's the motor behind the plastic that opens the lock clasp when the latch is used....it's like 70 bucks from the dealer...
Old Jun 23, 2010 | 04:30 PM
TypeRod's Avatar
Yeah Baysic R, I did more research and just like you said, its probably the actuator. I've ordered one and its about 70 bux shipped. I heart acuraoemparts.com. hehe! My R is slowly falling apart after 12 years, 175,000 miles. hehe! I just recently replaced the starter, now the trunk actuator...what next?
Old Jun 24, 2010 | 09:23 AM
fmrprojects's Avatar
I had the same problem on mines recently and changed out the latch on the trunk and now it works great
Old Jun 24, 2010 | 09:30 AM
thundernoodle's Avatar
lol mine is broken also
Old Jun 24, 2010 | 09:44 AM
lsd96teg's Avatar
If thats all you have had to replace with that many miles i would consider yourself lucky, not many cars can have that many miles and not have other issues
Old Jun 24, 2010 | 10:14 AM
sayanything's Avatar
i had this problem on my 01 gsr..
i experienced this latch problem 2X in about 1 week and this is what i do.
i unlock it, take the key out, and use 1 finger to slide the latch all the way to the right, open the hatch, and quickly move my finger so the latch "springs/snaps' back on its own.
ive opened my hatch 2x a day for the past year and no issues.
good luck
Old Jun 24, 2010 | 11:39 AM
3s1k's Avatar
When I open my and then close it it doesnt shut or catch on the latch as if there is no lock. I have to move the switch again and it makes a sound then it will shut properly. I alwas have to move the switch before I can get it to close tight.
Old Jun 25, 2010 | 02:31 AM
d8168055's Avatar
Hey, I am having a similar problem w. my lock.. I have to turn and hold the key to the right, then pull on the release to open. It used to open after unlocking the car (be it from the trunk or unlocking the doors)... could it be a fuse? or the actuator?
Old Jun 25, 2010 | 02:36 AM
itrSteez's Avatar
part #25
74840-ST7-A01 ACTUATOR ASSY., TAILGATE OPENER
Old Jun 25, 2010 | 07:33 AM
The Mista Mike's Avatar
So it's the actuator that's doing that? I hear the motor run, but it never unlatches.
Old Jun 25, 2010 | 07:53 AM
itrSteez's Avatar
Correct. It's a common problem.
Old Jun 25, 2010 | 09:46 AM
redGSRguy's Avatar
Originally Posted by itrSteez
part #25
Damn $60+ to open my hatch w/o the key...decisions decisions...
Old Jun 25, 2010 | 10:05 AM
RGoose18's Avatar
Welcome to the "hatch release not working" club............
Old Jun 25, 2010 | 01:16 PM
FormulaJDM's Avatar
Very common, replaced mine last year after 11 years.
Old Jun 25, 2010 | 03:59 PM
TypeRod's Avatar
hehe! Thats true. I did have the tranny rebuilt, well replaced 1st, 2nd, 3rd gear and the synchros of each of those gears, but that was back in 1999.
Old Jun 25, 2010 | 04:54 PM
94rs-turbo's Avatar
there's a write up on how to fix it yourself for cheap on here or on team-integra.com ya sorry too lazy to actually help ya'll find it but search and post it if you like
Old Jun 25, 2010 | 05:20 PM
itrSteez's Avatar
I'm going to buy a ton of these and price gouge once they aren't manufactured anymore
Tailgate Actuator 9.9/10 $4000 or trade for GSR
Old Jun 25, 2010 | 07:33 PM
baysic r's Avatar
glad i could help you out.....mine's on 130k but she's holding together....just would like to change out the window seals and rubber
Old Jun 25, 2010 | 07:39 PM
baysic r's Avatar
the key just dosen't unlock the latch.....try turning the key to unlock the clasp and lift the hatch up with the release and see what happens...
Old Jun 25, 2010 | 08:25 PM
RGoose18's Avatar
Hahahaha, hopefully that assclown has those seats in mothballs!
Old Jun 26, 2010 | 09:43 AM
d8168055's Avatar
This wont work... I have to hold the key in the right most position, while I release the clasp to lift the hatch... basically, I still need a key to open the hatch when the car is fully unlocked...
Y'all think that replacing the actuator would solve the problem?
Old Jun 26, 2010 | 01:44 PM
a808ITR's Avatar
Had the same problem also. Got to the point where i couldn't open or close the hatch and the simple replacement of the actuator solved the problems.
Old Jun 26, 2010 | 03:24 PM
jdm_94's Avatar
If you hear the motor run you jus need to change a little plastic part at the inside of the actuator and you will be find.mine was doing the same I went to the junkyard remove the plastic part from a donor car and install it in my actuator and done, like new again. I have two actuator but really i don't know if they works or not and I'm to lazy to take a part my R to try them in my car. I think that i will check them and put it in the sale section. LOL!!!!
vartok
May 21, 2014 05:03 PM
The_Ricky_Is
Oct 14, 2008 05:41 PM
pizzle
May 26, 2006 10:32 AM
roundworldsobig
Sep 27, 2005 10:53 PM
NUBREED
Sep 10, 2005 01:02 AM
