96 gsr wiring harness
can 96 gsr wiring with p72 ecu be used on civic si 00 with gsr swapped? are there amy other kit required or any kind of combine whateverso? do any of u happen to have pic of the gsr harness? i plan to buy one for 100 buck but they said they were not sure if its a gsr harness since they found it in the junkyard with the wiring harness inside on the floor of gsr car. please respone asap thanks
i see. but i think to myself what different does it make if i have p72 ecu and 96 jdm gsr swapped. and i plan to use gsr wiring harness. they are all matched to run gsr even the wiring? why do i required to use obd2b to hook up with 96 gsr swapped and p72 which belongs to gsr.
maybe i should try to clarify one more time. i got 96 jdm gsr swapped in my 2000 civic si. i have ecu of p72 for the motor. i got the jdm gsr wiring harness attached to the motor and ecu but it was for right hand drive. i found on craiglist, the guy wants to sell 96 usdm gsr wiring harness which the guy found it inside of the gsr car on floor at the junk yard, the car was theft recovered. so i think to my self it should run perfectly since it is gsr compatible.
As someone already stated you cannot use a GS-R harness in a '96 - '00 Civic. They're a completely different design. What you need to do is reuse the civic harness, add the wiring for the IAB sensor and either use an OBD2B to OBD2A conversion harness, or run an '00 - '01 USDM GS-R ECU with the immobilizer removed.
ok anybody here have 99-00 civic si harness for sale? i need both two harness from the below battery components which is wiring harness to the motor and the another one at the end on left by driver side, what is it called? i believe it is connencted to the cluster?
*also it does not have to be the 99-00 Si harness. u can also use the 99-00 EX harness. they are BOTH wired for VTEC. Or u can use a Non-vtec harness and wire in VTEC yourself.
