Replacing Swaybar Endlinks
My endlinks have seen better days in 10yrs and i'm replacing them. Helms says that you should put full vehicle load on them before tightening the nuts. How does one go about doing this? Do you simply use a second jack to push the knuckle upwards?
You can either lower the car back to the ground and then tighten them (if your car isn't super slammed) or put a jack under your lca, jack it up, then tighten it.
VTEConly
Aug 14, 2004 08:17 AM
