Suspension & Brakes Theory, alignment, spring rates....
Are wheel Studs from a 92 interchangeable with a 99?
Old Jun 22, 2010 | 06:35 PM
Shinny's Avatar
Default Are wheel Studs from a 92 interchangeable with a 99?
A new co-worker pulled up in a 92 thats modded out the butt and he's looking for something more stock. Which I have, but I just put in extended studs for autoxing. If a trade happens would I be able to switch my studs onto his car?
Old Jun 22, 2010 | 08:12 PM
xd69's Avatar
Default Re: Are wheel Studs from a 92 interchangeable with a 99?
yes
Old Jun 23, 2010 | 04:52 AM
dpetro1's Avatar
the studs are interchangeable but there is no way i would spend all the time to swap. just add studs to his car.
Old Jun 23, 2010 | 06:37 PM
Shinny's Avatar
Turns out its an accord, same bolt pattern and all that from what I can tell. Just want to make sure I can put my race tires on it.
Old Jun 23, 2010 | 07:37 PM
98civdx's Avatar
Master Detailer
Yep, but its really not worth it, a lot of work for 100 bucks
Old Jun 24, 2010 | 04:57 AM
dpetro1's Avatar
accords have a 4 x 114.3 bolt pattern, civic is 4 x 100. so no you cant swap your wheels onto his car. why would you want to race an accord anyways, they are heavy and wont handle as well as your civic
Old Jun 24, 2010 | 05:06 AM
wolfy47's Avatar
^^^ facepalm...i take it that you also think sohc's are really bad engines to mod
Old Jun 24, 2010 | 05:52 AM
dpetro1's Avatar
im not tryin to hate on accords, its just strange that the OP already seems to have an auto-x setup for his civic but wants to trade for a "moded out the butt" accord that he will need to do more work on to be track ready.
Old Jun 24, 2010 | 12:14 PM
Shinny's Avatar
It's got dohc, my civic rolls like a bitch and has sohc. Also the money it would take to get my car as fast as that one would be way more expensive. The accord is slammed has strut bars, slotted and drilled front brakes and slotted rear brakes, headers, stainless steel exhaust, carbon fiber hood, cold air intake, its sitting on 17's right now but I wouldn't use those. And now that I think about it the rims I have have two sets of holes. One 4x100 but idk what the others are. Possibly 4x114.3? how do I check?
Old Jun 24, 2010 | 12:19 PM
Shinny's Avatar
My Civic runs St because of the Cold air intake I bought a long time ago. The frame is bent so I can't lower it without fixing. It's basically turned into a money trap. I do have tokico Illumina struts but 10 year old springs. I've put more money than I paid for it into just fixing stuff I broke when I put it through a speed limit sign at 60 racing through a neighborhood. (before I knew about autox)
Old Jun 24, 2010 | 12:34 PM
98civdx's Avatar
Master Detailer
Normally, it will be 4x114.3, and 4x100.
Old Jun 24, 2010 | 07:42 PM
Shinny's Avatar
Yeah didn't think there could be too many options in the 4 bolt pattern range.
Old Jun 24, 2010 | 07:43 PM
Shinny's Avatar
Oh and I'm going to buy it if I get it at all. He only paid 1.8k for it, so I can do that instead of spending that money to get my car started towards being competitive.
93grayeg
Jun 7, 2013 07:33 AM
timmy0tool
Oct 1, 2007 12:10 PM
amtrak23
Nov 19, 2005 07:38 PM
jarel
Jul 24, 2002 10:36 AM
4doorH22
Jun 2, 2002 01:30 AM
