help....
Old Jun 21, 2010 | 08:18 PM
CleanGSRek9's Avatar
Default help....
hay guys new to site have couple questions, i have a odb1 gsr swap and my idle is messed up, when going into neutral the rpms will stay at 2k until i stop then bogs down and almost dies, weird thing is that if i stick my foot behind gas peddle andl ift up my idle comes up to 750 and stays there, i have already cleaned the iav and throttle body, question is i have a obd2 p72 and if i use that ecu my idle is perfect and not rough, my obd1 ecu is p28 on chrome, im wondering if it wod be fine to use the obd2 ecu on obd1 swap? any insight would be appretiate....
Old Jun 21, 2010 | 08:26 PM
dxlol's Avatar
Default Re: help....
check your throttle cable tension?
Old Jun 21, 2010 | 08:31 PM
its not very tight, its weird tho with the p72 it idles great but wit the p28 it sucks, jus wondering if its safe to use the obd2 ecu on a obd1 swap
Old Jun 21, 2010 | 09:15 PM
anyone have any opinons, open to try anything to fix the problem
Old Jun 21, 2010 | 09:23 PM
solb20's Avatar
check ur codes on the ecu some kind of input is missing thats why its doing that
Old Jun 21, 2010 | 09:57 PM
i have no codes on the p28, and jus my o2 sensor codes come up with the p72 in
Old Jun 21, 2010 | 11:27 PM
gnite bump
Old Jun 22, 2010 | 02:09 PM
bump
Old Jun 23, 2010 | 12:12 AM
help
boostgoblin
Engine Management and Tuning
Dec 27, 2017 07:51 PM
tatayee
Jan 26, 2014 07:19 PM
mkeacura
Aug 26, 2013 11:07 AM
scott_turner
Aug 26, 2011 12:51 PM
jdm_vtec
May 24, 2007 01:19 PM
