I May Put An 06 RSX Type S K20 Motor In My EG I've Researched Just Need More Info???
Old Jun 21, 2010 | 01:28 PM
CRAZY-EG9's Avatar
Icon2 I May Put An 06 RSX Type S K20 Motor In My EG I've Researched Just Need More Info???
I May Put An 06 RSX Type S K20 Motor In My 94 EG due to such a great deal on the full swap through a friend that is only giving me such a deal. I've Researched the stickies on K20A.org and found some info, haven't had much time to search this site, maybe could have found more info but I very rarely have computer time, so all i keep seeing and hearing is something about VSS-(Dont really know what it is) and speed the speed sensor not working different tranny mounts. i know about the drive by wire issue with the throttle body and i keep also hearing about the engine wire harness. Just Need More Info???
All I want is for you guys to explain every issue I need to know & those issues cheapest alternatives????? Sorry I'm a former Bseries & Hseries guy
Old Jun 21, 2010 | 01:34 PM
H22EG'z's Avatar
Default Re: I May Put An 06 RSX Type S K20 Motor In My EG I've Researched Just Need More Info
um, i have an 04 type S in my EG.
Harness =swap harness
VSS= that IS your speed sensor and that's in the trans, i don't see what the issue is with that*may be something im not aware of* buy a Hasport mount set and it will all fit in fine.
you can use the EG wire for the Drive by wire its just long as hell and i think you get the wire fork that holds it on the Intake from a CRV.. i think.
... ill post a pic later of that stuff.
Old Jun 21, 2010 | 02:04 PM
CRAZY-EG9's Avatar
thanks, anymore info people
Old Jun 21, 2010 | 03:32 PM
CRAZY-EG9's Avatar
Old Jun 21, 2010 | 04:22 PM
jerryegk24's Avatar
Drive by wire only comes in 06up si and Tsx motor. The 05-06 rsx-s tranny will work but the vss will not work so your mph gauge will not function.I think the 05-06 rsx tran's vss is internal not like the external vss. Swap 02-04 rsx tranny. 02-04 rsx-s engine harness, hasport sub harness is plug n plug easy. Tsx tranny will not fit the chasiss but they might have made aftermarket mounts for it but not sure yet.
Old Jun 21, 2010 | 04:34 PM
CRAZY-EG9's Avatar
I also heard something about the 06 VSS locking you out of reverse. What's that about????
Old Jun 21, 2010 | 04:41 PM
H22EG'z's Avatar
[IMG][/IMG]
there is the TB and the wire and stuff..
as far as the reverse lock out... i've heard of it but i didnt look into it since im rolling an 04.
Old Jun 21, 2010 | 05:12 PM
pogeeboy27's Avatar
Check out the stickies at the top of this section on K20A.org: 1992+ Civic EG / DC2 / EK K-Series Swap. It answers your questions about VSS as well as others you may have about swapping your motor into a 92-95 Civic. Good luck.
Old Jun 21, 2010 | 05:24 PM
CX-Adam's Avatar
talks to himself
Community Builder
Community Influencer
Didn't read through this thread but here's a link that has a ton of K-Swap info.
http://www.hybrid-racing.com/tech/install-guides/
I feel your pain dude. There's so much to research!! Good luck!
salvi2dafullezt
Northeast (Sales)
Jul 15, 2012 07:48 AM
SupraRXZ
21
Jun 3, 2007 12:32 PM
spoonhybrid
Jan 7, 2005 09:25 PM
K20 EG
May 25, 2003 08:33 PM
