another fuel issue.
Old Jun 21, 2010 | 10:40 AM
88HATCH(:'s Avatar
Default another fuel issue.
okay so i have fuel to wht i think is the main line (3 tht i see) the one tht has fuel is the one the goes straight to the fuel injection system right after coming off of the firewall.
and i pull off the lines going to the cansiter looking deal (fuel filter?) and the lines are dry.
also the last line is empty as well, which of the two is the return line and which do i need to get furl to?
please any help is appreciated
Old Jun 21, 2010 | 11:44 AM
dcraige's Avatar
Default Re: another fuel issue.
Here you go. Turn your key to run and you should have fuel coming form the one labeled 'fuel line'.
Old Jun 21, 2010 | 12:01 PM
88HATCH(:'s Avatar
thanks alot, ight i ot fuel, now another question, there is fuel whe its needed, but fuel isnt getting to the injectors, i checked the fuse box, and fuses 1-5 (bigger ones) are missing? would this have something to do with it?
Old Jun 21, 2010 | 12:04 PM
dcraige's Avatar
Can you hear your fuel pump turn on for 2 seconds when you turn you key to the run position?
Old Jun 21, 2010 | 12:13 PM
88HATCH(:'s Avatar
yeah, i have fuel pressure and everything, just for some reason the injectors wont squirt ?
Old Jun 21, 2010 | 12:26 PM
dcraige's Avatar
When you turn your key to the run position does your oil light come on? And Does you Check Engine Light Come on then go out after 2 seconds?
Old Jun 21, 2010 | 12:32 PM
88HATCH(:'s Avatar
both come on and the engine light goes away after the two seconds
Old Jun 21, 2010 | 12:45 PM
dcraige's Avatar
Check your resistor box. Its located under the hood between the firewall and the driver side fender. Disconect the plug and check the resistance with a multimeter. Check A to B, A to C, A to D and A to E. You should have 5-7 Ohms of resistance between each one. 'A' is the one on the top left if you are looking into the plug.
Old Jun 21, 2010 | 12:50 PM
88HATCH(:'s Avatar
is it the plug mounted on top of the fender?
its the only plug i can find, its a circular style.
Old Jun 21, 2010 | 12:57 PM
dcraige's Avatar
It looks like this
Old Jun 21, 2010 | 02:02 PM
88HATCH(:'s Avatar
my car doesnt have anything like tht
Old Jun 21, 2010 | 02:45 PM
dcraige's Avatar
Well, what engine do you have? What type of car? Why do you think it's the injectors?
Old Jun 21, 2010 | 02:49 PM
88HATCH(:'s Avatar
its an 88 civic hatch.
its has a d15b
i think its the injectors because i have fuel presure to the system, but the injectors wont squirt so i dont think imgetting powerr to the injectors? but i honestly have no idea whts wrong?
Old Jun 21, 2010 | 07:00 PM
dcraige's Avatar
You can use a hose on the injectors to hear if they are clicking.
Old Jun 21, 2010 | 08:57 PM
88HATCH(:'s Avatar
and if theyre not should i replace the ecu, or look else where ?
Old Jun 22, 2010 | 07:04 AM
dcraige's Avatar
PM sent.
Rikaro
Sep 25, 2009 11:36 PM
Christopherian1982
Dec 31, 2008 08:17 AM
hondastudent1on1
Jul 5, 2008 02:54 PM
LBR92DA-T
Oct 25, 2003 02:21 AM
LBR92DA-T
Oct 24, 2003 07:48 PM
