sohc builds?
Old Jun 21, 2010 | 09:49 AM
JDM4LIFE90's Avatar
Default sohc builds?
whad up HT
so recently i aquired an eg and this time its a sohc (d15b7 non vtec), ive had a few hatches and a del sol but theyve all been dohc's.
i thought it would be interesting to build a sohc, (read super streets 700whp sohc ef wagon build) but i dont really know much about them or how to approach a build setup
with the sale i also got a d16 vtec head, with a p2p ecu and obd conversion harness
so i guess here are my few questions
1.
do any b series parts fit d series motors? and would what would be a good trans? its a 5 speed now, but is it possible to put a bseires tranny in? or would i have to go si for different gearing?
2.
i know b series have an intake and exhaust cam and gear, and different valves, when it comes to d series parts are they made different, spec wise im assuming, and just in general?
3.
if the different series dont comply would i be able to bore and mill everything out to make them fit?
4.
ive been having a little trouble finding legitamate sites that have d series parts... would i be better off doing a b series swap?
Old Jun 21, 2010 | 10:01 AM
Linked's Avatar
Default Re: sohc builds?
d-series.org and turbod16.com are solely dedicated to the sohc motor, they provide more information for what your looking for
Old Jun 21, 2010 | 10:14 AM
Sales@Bisimoto.com's Avatar
Bisimoto Engineering carries alot of D Series stuff, and if theres stuff you they don't have Im sure they can source it for you!
Old Jun 21, 2010 | 10:27 AM
apexi_rsx's Avatar
you want to build a z6 or a6 block. the new cranks from a y8 and y7 only have one oilling hole for the rods as the older blocks had 2. maybe why the newer motors tend to spin rod bearings. depending if ur in a budget or not you can do an eagle vitara build or go with a better build with arias and scat rods. bisimoto has been to make the best boost cam for the sohc. if your looking for over 300hp i recomend a nice garret gt30r. tune on a hondata s300 or get a chipped ecu and run chrome pro
Old Jun 21, 2010 | 01:47 PM
JDM4LIFE90's Avatar
nice, thanks for the replies, ill start doin some homework, ill keep up with the update if i decide to start the build
buildit
Nov 20, 2008 07:45 AM
bluedelsol
May 23, 2003 04:32 PM
DSC
Aug 12, 2002 07:28 AM
fcuked
Jul 10, 2002 03:17 PM
