my b20vtec compression?
I have stock b20b block with rs machine 11.8cr type r replicas, have a b16 head with .10 shaved off of it. What would the c/r be? How much more compression can I go up to n still run 93 octane, I've heard 13.0? How much compression does it add when u take .10 shaved off of the head? Thanks for the help guys
your probably at around 12-12.2 :1 com ratio.
you have a long way to go before you hit 13:1 with those pistons.
with whatever head and cams you slap on that you can still run 93 because of the comp ratio. as long as you have a good tuner.. any **** tune/tuner can blow anything up.
Thanks that's what I was thinking it was, I have it together already runnin on basemap from phearable with b16 head. Just ready to bump it up n port/polish the head wit some skunk2 pro2's, get the comp r up as high as possible with 93 octane
