clear coat question need halp asap
Old Jun 21, 2010 | 05:28 AM
vtechappy's Avatar
Default clear coat question need halp asap
ok here it goes.. i had to paint my door on my del sol because it was back n nasty and scratcy. well i got the right color and everything.. every time i clear coat it it look all blotchey and dosent lay right.. i just want it too look normal
any tip please
thanks
Old Jun 21, 2010 | 06:06 AM
candyman206's Avatar
Default Re: clear coat question need halp asap
Need the right activator for the temperature. You could try to adjust the gun to spray more material, slow down, or get closer.
Old Jun 21, 2010 | 09:12 AM
vtechappy's Avatar
im using a rattle can tho
Old Jun 21, 2010 | 03:24 PM
aystupet's Avatar
You're probably spraying too close..
Old Jun 21, 2010 | 04:32 PM
Spawne32's Avatar
Old Jun 21, 2010 | 05:06 PM
nsxter's Avatar
Originally Posted by Spawne32
this is the first time but i have to agree
Old Jun 21, 2010 | 05:55 PM
vtechappy's Avatar
you guys are asses
Old Jun 21, 2010 | 06:28 PM
nsxter's Avatar
you guys are asses
your the dumass thats clear coating a car with spray paint
Old Jun 21, 2010 | 07:13 PM
vtechappy's Avatar
fine ill bust out the compressor and get the pary gun
Old Jun 21, 2010 | 07:25 PM
bee24's Avatar
You might want to check the little hole on the cup of your gun, if it's clogged the clear prolly want lay right. If that's not it, turn the air pressure up a little.
KILLAB17VTEC
Paint and Body
10
May 1, 2009 02:16 PM
gemineye716
Paint and Body
Aug 22, 2008 10:54 AM
InTeGrA_bLazEd
Paint and Body
Jun 9, 2007 03:31 PM
mongoliandonuts
Jul 22, 2004 07:58 PM
