Ratio Question? Need Answerd ASAP!
Old Aug 18, 2008 | 03:00 PM
gemineye716's Avatar
Default Ratio Question? Need Answerd ASAP!
alright,bodywork. Check. primer. check. wet-sand. check. i jus finished taping off my car. and its ready to paint. im just being cautious. seeing that there are some paint experts on here i just wanna know:
is 8:4:1 (Finish:Reducer:Hardener) the proper ratio or no?. just wondering. also i am posting pics up after the job is completed.
im whippin round' a 97' accord lx. and i want this biotch to look nice.
fyi, i do paint for a living, but automotive wise this is a first. so i have the sprayin techniques down pat. jus bein cautious on the ratio.
also. i am repainting it the same color, how many coats should it take? there are only 2 spots that needed primed. the other spots the clear was peeling and i jus feathered edged it.
finally, any suggestions or expert tips on anything i left out would be nice too.
EDIT: i also wanta know if it is safe to paint my rims with the tires on them (ill obvioulsy tape them off and all that.)
Old Aug 18, 2008 | 08:25 PM
integrapunk67's Avatar
The ratio depends on the product.
Old Aug 19, 2008 | 02:23 PM
powerflow's Avatar
Default Re: (integrapunk67)
Just follow the tech data sheets on the exact product line. You should have inquired about the mix info when you bought the paint. Suppliers usually will provide the data sheets on request.
Generally: Dupont and PPG base typically is 1:1, BASF RM base is 2:1 base/reducer
You can paint the rims with the tires mounted. Depends on the lip edge, sometimes you need to deflate and break the bead to get at the edge. I've done plenty of rims without removing the tires. There are pro's of doing this way, don't always have to balance again, don't have to worry about tire machine or balance machine ruining the fresh paint. You can't always get away without a re-balance after paint. If you repair the wheel, ect the weight could be thrown off balance.
Here is a pic for reference.
Old Aug 20, 2008 | 01:55 PM
my paint is martin senour, i found the tech sheet (http://www.martinsenour-autopaint.co...glish/9104.pdf) it says i can buff after 48 hours? i guess ill give that a try, btw where can i find a good buffer for cheap?.
and, thanks for the heads on up paintin my rims with the tires still on. could i use the car paint i have, cuz i wanna math my rims to the car. or do i haveta buy "wheel" paint?.
Old Aug 22, 2008 | 10:54 AM
Mr Yamada's Avatar
Default Re: Ratio Question? Need Answerd ASAP! (gemineye716)
perhaps you should learn to spell and use punctuation, after all YOU are the Person calling others crackheads when they post information
-16V-
Paint and Body
Jul 15, 2009 10:26 AM
Infamous
Mar 1, 2006 03:29 PM
Captain Flaps
Dec 19, 2005 08:30 PM
Brian-Brian
May 18, 2003 09:06 PM
