<br>Brake lights<br>
Old Jun 21, 2010 | 02:02 AM
EGKevin209's Avatar
Icon6 <br>Brake lights<br>
idk what happend but i brakes hella hard and for some reason my break lights stayed on :/ what can b the problem. it doesnt shut off, help me out. thanks!
Old Jun 21, 2010 | 02:25 AM
Nichelson_Performance's Avatar
Default Re: <br>Brake lights<br>
brake light switch which are typically found up under the dash of most vehicles and are attached to a mounting bracket which allows the brake pedal when released to push in on a switch which shuts power off to the brake lights.
most of the time they work loose, though I've never had this problem on a honda, I've had it happen on many other vehicles that use a threaded type brake light switch
Old Jun 21, 2010 | 07:40 AM
delsolo95's Avatar
check the rubber or plastic part on the pedal that will touch the brake light switch when foot is off. its probably broken easy fix and is cheap at the dealer!
Old Jun 21, 2010 | 08:36 AM
Gunmetal_B20_Hatch's Avatar
x2
Old Jun 21, 2010 | 09:14 AM
D16SiHatch's Avatar
yep^
https://honda-tech.com/forums/honda-crx-ef-civic-1988-1991-3/brake-lights-wont-turn-off-2332740/
Old Jun 22, 2010 | 02:39 AM
EGKevin209's Avatar
thank you guys
Old Jun 22, 2010 | 08:24 AM
shawn_crx's Avatar
What do you mean by brake light, is it your brake light in the back, or your brake light in the cluster?
Old Jun 22, 2010 | 12:41 PM
EGKevin209's Avatar
brake lights in the back
Xzay01
Lighting
Jun 14, 2013 08:53 AM
ihonda
21
May 31, 2012 09:53 AM
asocallocal
Aug 29, 2010 07:00 PM
neogenesis2004
Mar 3, 2009 04:21 PM
musclehead954
Feb 27, 2008 10:28 AM
