Soda blasting or sand blasting a manifold?
Old Jun 20, 2010 | 07:34 PM
siblues's Avatar
Default Soda blasting or sand blasting a manifold?
I have a ramhorn manifold made of stainless material and I was wondering if blasting it will have any adverse affects on the material?Are any methods better for cleaning the manifold and preventing any damage/Thanks
Old Jun 21, 2010 | 01:25 PM
Lugzilla's Avatar
Canuckian
Default Re: Soda blasting or sand blasting a manifold?
You're good to go. Bead blasting is pretty much harmless to that, it will only take off the loose sh*t on the surface and take away the shine.
Old Jun 21, 2010 | 02:17 PM
Bailhatch's Avatar
What kind of finish do you need/want? Sandblasting will get it totally stripped, but the surface will be rough and will get dirty very fast if you're not ceramic coating it. I don't think soda would do enough to remove coloring, but would deffinatly clean it pretty well. Walnut shell and corn cob are not hard enough to do much of anything.
Old Jun 21, 2010 | 02:37 PM
g-gameslude18's Avatar
glass bead blasting + vht 2000* header paint.
Old Jun 21, 2010 | 11:05 PM
siblues's Avatar
Well I am just looking to get the surface totally clean and remove all the discoloration and start fresh.
Old Jun 22, 2010 | 09:11 AM
Snow Trooper's Avatar
OG Fabricator
you are not supposed to use glass bead as a blast meduim when painting or coating afterwards, use aluminum oxide.
if you are just cleaning it and dont want a paint surface use soda blasting. as mentioned the "sand blasting" will leave a rougher pitted finish.
BDogggUT34
May 23, 2007 03:04 AM
Fatty_1775
May 27, 2005 08:09 PM
oxSLEEPERxo
Oct 21, 2004 11:16 AM
dominate9
Mar 16, 2004 07:05 AM
eg2turbo
Nov 25, 2002 11:40 AM
