horn stopped working
Old Jun 20, 2010 | 08:10 AM
LiL JoN's Avatar
Default horn stopped working
so a couple days ago my horn stopped working i have a 99 civic si with nrg quick release and hub was working fine but stopped working all of a sudden when i press the button i hear like a click coming from the underdash fuse boxand also my keyless remote dosent honk when i lock it.........any suggestion ........
Old Jun 20, 2010 | 08:33 AM
delsolo95's Avatar
Default Re: horn stopped working
have you checked your fuses and grounds??
Old Jun 20, 2010 | 08:46 AM
Thump_eg94's Avatar
it dont sound like your relay went because u wouldnt hear the click check in the bumper and see if your getting power to the horn itself
Old Jun 20, 2010 | 09:01 AM
LiL JoN's Avatar
ill check today the fuses ....what grounds on the engine???
Old Jun 20, 2010 | 10:03 AM
delsolo95's Avatar
the one near the horn in front of the car. my sister ej8 ground keeps coming loose i was like wtf!
Old Jun 20, 2010 | 09:58 PM
LiL JoN's Avatar
ill check tommorow
Old Jun 21, 2010 | 04:46 PM
quapouh's Avatar
SRS light is "ON"? is so it could be your srs reel that has wires for both airbag deployment and horn button (even if you hanged your steering wheel to the fancy stuff
Old Jun 21, 2010 | 08:53 PM
LiL JoN's Avatar
no its not on ......^^^^^^
Old Jun 22, 2010 | 11:24 AM
deadazleep's Avatar
if it was the SRS wheel causing the problem then the horn would still work with the keyless remote. Sounds like a fuse or loose connection somewhere
Old Jun 22, 2010 | 11:34 AM
JDM_SOHC's Avatar
Maybe the horn wire came out of the yellow srs plug in the steering column, did you check that..??
Old Jun 22, 2010 | 09:22 PM
LiL JoN's Avatar
no i havent ill check that tommorow thanks ........
jhendry
11
Jul 29, 2009 10:31 AM
zenon8890
10
Nov 16, 2008 04:42 PM
Vagabund07
Jan 12, 2007 08:48 AM
hookedonvtec
Feb 8, 2005 05:30 PM
tianporn
Jan 29, 2005 09:16 PM
