Ls/v
Old Jun 19, 2010 | 09:11 PM
UndisputedH22a's Avatar
Default Ls/v
Im wanting to build up an ls vtec all motor with reliability need some help on some parts goal is 190-210whp.
I know this so far
B18b1 Block
Shot Penned Ls Rods
Type R Pistons
Arp Rod Bolts
Arp Head Studs
Golden Eagle Ls/v Kit
Anything Else...
B16 Head
What Cams,cam gears,valves,springs,and retainers should i go with anything else that could help me get a hi power decently to good reliable ls vtec set up would help.
Old Jun 20, 2010 | 05:31 AM
Default Re: Ls/v
morning bump
Old Jun 20, 2010 | 08:44 AM
00Red_SiR's Avatar
All Motor Mentor
Default Re: Ls/v
take a look at the all motor 1.8L dyno to get an idea of what cams and part combinations will make the power you want.
Old Jun 20, 2010 | 10:05 AM
tempsohc's Avatar
Default Re: Ls/v
Guy knows a lil something something.
Old Jun 20, 2010 | 11:12 AM
jv88_dc2's Avatar
Default Re: Ls/v
For the head, you cant go wrong with Skunk2 EVERYTHING. Valves, springs, retainers, cams, manifold
Old Jun 20, 2010 | 11:24 AM
fsg231's Avatar
Default Re: Ls/v
thats what im doing
Old Jun 20, 2010 | 12:15 PM
Trk2112's Avatar
Default Re: Ls/v
my ls/v made 187 with ctr pistons and s2s2 cams with crappy dc headers and a stock exhuast.
Old Jun 20, 2010 | 06:28 PM
Default Re: Ls/v
Ok im cool with a full skunk2 head what about pro2 cams, and a 3angle valve job. also anything else i am missing to keep this built motor reliable?? alright went through a good bit of that dyno thread and seen nice set ups just need everthing else that is a good idea to put in my motor so its a good set up
Old Jun 20, 2010 | 06:46 PM
Rollo Lawson's Avatar
Default Re: Ls/v
lol
Old Jun 21, 2010 | 04:23 AM
fsg231's Avatar
Default Re: Ls/v
Originally Posted by UndisputedH22a
Ok im cool with a full skunk2 head what about pro2 cams, and a 3angle valve job. also anything else i am missing to keep this built motor reliable?? alright went through a good bit of that dyno thread and seen nice set ups just need everything else that is a good idea to put in my motor so its a good set up
pro 2's might be over kill, im doing a similar build, but with b16 pistons... i have a typeR head with everything skunk, but im going with pro 1's even those may be a bit much...
with the pro 2's your going to give up a bit of driveabilty and bottom-midrange power... i would say, for you the tuner 2's or the pro 1's like me
Old Jun 21, 2010 | 04:43 AM
negusjuda's Avatar
Default Re: Ls/v
ut oh here comes the tuner 2 vs pro 1 debate again lol i see it coming
Old Jun 21, 2010 | 08:08 AM
Default Re: Ls/v
i dunno really just want something good i was debating on pro2 vs tuner2
Old Jun 21, 2010 | 08:28 AM
fsg231's Avatar
Default Re: Ls/v
thats a HuUUUUGE difference...you should be debating between pro1's and tuner 2's
there a 10 page thread somewere in the all motor section about these cams for ls/v... unless your building a full out race motor you would hurt power withthe pro 2's...alos the valves would probly hit the pistons with them
Old Jun 21, 2010 | 08:40 AM
neverstop's Avatar
Default Re: Ls/v
you can make 190-200whp easy with type r cams and have no headaches with reliability and idle and valve springs, etc. the other cams use more rpm and that lowers motor life. if i was going to be happy with 190whp then I'd probably just use the itr cams.
Old Jun 21, 2010 | 09:31 AM
gixxerboy750's Avatar
Default Re: Ls/v
i would stop worrying about the head and buy a crank girdle for the block and type r oil pump. If you want theres some people that have put in oil squatters in the blocks for even more reliability. And if its a daily motor, don't take it past 8,200rpm's. That's just what i would do for a solid strong motor.
Old Jun 21, 2010 | 09:57 AM
OH_1fstgsr's Avatar
Default Re: Ls/v
Please define easy. I am at 190whp with ITR cams and it was not easy or cheap.
If I had a 89mm crank maybe, that would have given me 5-10whp. I also still have PS hooked up, maybe a few more there.
I would look at S2S2, Pro1, BC4, RM22x, JUN3, BISI Level 3.
If you have a well built set-up any of these should get you in the power range you seek.
Old Jun 21, 2010 | 01:54 PM
Default Re: Ls/v
So would ITR camshafts be good for a b16 head with out having to replace my valvetrain? and i guess i need a vtec water and oil pump and i dont know anything about a griddle?
Old Jun 21, 2010 | 02:31 PM
Na-Spirit's Avatar
Default Re: Ls/v
Here's a lsvtec with pro 2 cams. Rsmachine pistons/stock rods etc, cccylinderheads head work
obviously works fine..check the dyno vid, 226whp
https://honda-tech.com/forums/showth...723025&page=13
Old Jun 21, 2010 | 04:19 PM
Default Re: Ls/v
just go b20 vtec if your goin all motor, alout more torque and thats what it comes down to in a allmotor race and shop around for a block girdle. There all great and will DEFENETLY save you're bottom end.
Old Jun 21, 2010 | 04:31 PM
Default Re: Ls/v
yea but what was his compression and exhaust size and what tuning program is he using. You need the lower end power to back up a high lift cam like pro2's.
i would say get a great port job on you're head and do supertech 12.1 compression pistons, stock rods arp rod bolts, block girdle, type r oil pump.
skunk 2 pro1's and supertech flat valves with springs n retainers.
camp1320 header or ssr header or bisimoto header
2 1/2" straight through no cat no rez just muffler
3" intake piping cold air, into a 70mm throttle body and edelbrock victor x intake port matched to the head.
440cc injectors,
with a good tuner on pump gas, ull be a happy customer. LOL
that's what i would do lol.
Old Jun 21, 2010 | 05:31 PM
Default Re: Ls/v
So what if i did B16 Head Skunk2 Tuner Stage2 Cams,Dual Springs,Valves,and retainers,along with Pro series cam gears?
pinoy_boi
18
Sep 4, 2012 06:43 PM
JDMbitches
16
Aug 15, 2006 09:25 PM
hatchmonkey92
May 5, 2005 09:25 AM
ChaseIntegra
Jun 13, 2003 01:36 PM
juicedricer
14
Mar 17, 2003 03:14 PM
