Trick to slide spline all the way into spindle - HELP
Old Jun 19, 2010 | 09:06 PM
braass91's Avatar
Default Trick to slide spline all the way into spindle - HELP
I am replacing the front axle on the passenger's side on my 91 Hatch DX. Everything is easy except putting back the outer spline into the spindle. I can't get the axle to slide all the way in so I can install the axle nut. Thanks.
Old Jun 19, 2010 | 10:31 PM
JDMkid413's Avatar
Default Re: Trick to slide spline all the way into spindle - HELP
knock the bottom ball joint loose and it will be cake
Old Jun 20, 2010 | 05:50 AM
gibsanez's Avatar
Tie rod works too doesn't it?
Old Jun 20, 2010 | 09:14 AM
braass91's Avatar
I did this when I removed the old axle. I am install the new axle but I can't get the outside spline to slide all the into the spindle so I can put on the axle nut.
Is there a trick to do this? Thanks
Old Jun 20, 2010 | 09:19 AM
k20rex1's Avatar
this is the way to do it.
Old Jun 20, 2010 | 09:38 AM
gibsanez's Avatar
If all else fails just remove the hub from basically everything attached to it.
Old Jun 20, 2010 | 09:48 AM
BrayzieEF9's Avatar
are u sure the spline is lined up?? lol it should slide right in if ur lined up.i did 2 axles yesterday.
Old Jun 20, 2010 | 10:34 AM
jdmwannabee's Avatar
sometimes you have to use force... it doesn't always slide in. also, if you have some anti-seize or something, grease the splines and the hub and that'll helpyou .
Old Jun 20, 2010 | 12:27 PM
BrayzieEF9's Avatar
you dont use force if none of your splines are lined up dummy,your gonna end up damaging the spline.you can use for force when part of the spline is inserted and take a rubber mallet and hit the rotor.
Old Jun 20, 2010 | 01:28 PM
sh!ft's Avatar
Who the fack changed my title?!
smack the cvaxle into place with a rubber mallet, then take off the lower controll arm from the CHASSIS, pull back, slide cv axle in, bolt lca back on and put nut on
edit: get a friend to smack the cv axle in while you "walk it in" i advise to use gloves of some sort
Old Jun 20, 2010 | 03:54 PM
i hope you weren't referring to me as a dummy... if you read the OP, he can't get the axle all the way in... and if force weren't required, explain what taking a rubber mallet and hitting the rotor would be an example of...
Old Jun 20, 2010 | 08:45 PM
BrayzieEF9's Avatar
you dont use force if none of your splines are lined up dummy,your gonna end up damaging the spline.you can use force when part of the spline is inserted and take a rubber mallet and hit the rotor.
Old Jun 20, 2010 | 09:40 PM
braass91's Avatar
I finally did it....with a little force.
Old Jun 20, 2010 | 09:54 PM
BrayzieEF9's Avatar
^ nice that took a while
grjr
Aug 23, 2012 04:12 PM
jmurphy
17
Apr 5, 2011 01:19 PM
flaxx0r
28
Dec 29, 2008 07:15 AM
PIC Performance
Dec 4, 2005 07:12 PM
