cooling fan an a/c fan problem
Old Jun 18, 2010 | 04:08 PM
josemt's Avatar
Icon2 cooling fan an a/c fan problem
hello, I have 1995 accord v6 the car is overheating because the cooling fan wont turn on I check the relay and works the plug ins good to so I decide to wire to the fan the fan turns on so that means the fan work
and the a/c fan doesn't work either did the same with cooling fan check the relay and wire to see if works and it works can some one help me
thank you for all the help
Old Jun 18, 2010 | 04:50 PM
poorman212's Avatar
Default Re: cooling fan an a/c fan problem
I'm not really following you, sorry.
"I check the relay and works the plug ins good to so I decide to wire to the fan the fan turns on"
Voltage to the fan motor and it works, YES the motor is good. Why is the motor NOT getting voltage is the question. Fuse, relay, sensor, switch. Need to work our way back and answer why the voltage isn't getting to the fan.
Can you help with a few more details as to what has/hasn't been tested?
Are both fans not working. AC off and car gets hot, do or which fans come on. Car cool and with AC on both or which fans come on?
Old Jun 18, 2010 | 05:02 PM
nus_dogg's Avatar
This is what I did when I had the same issue. I gave both fan motor(A/C & Rad fan) power and ground, so if the fan motors run, that eliminates the wires, fuse, and relay and vice versa.
What I did to the cooling fan relay(4 prongs relay) for diagnoses is use a OHMmeter checking for continuity between two prongs on the relay, so whatever two prong has continuity means that thats the coil that current flows through to pull the points of the other two prongs. So you give the two prongs that has continuity ground and power, that should make it click. If not, there's an open in the coil inside the relay. I've heard of working relay still goes bad even though they click with power sending through them; thats cause the points are burnt and pitted, not enough contact to send current through the contact points.
I did all this and everything checked out good, and so I went to the fuse and what do you know. It was a blown fuse.
Hope this help.
Old Jun 23, 2010 | 06:24 AM
Duane_in_Japan's Avatar
https://honda-tech.com/forums/honda-accord-1990-2002-2/diy-c-cooling-system-2793650/
Start here, let us know what you find.
Si joey
Oct 21, 2015 09:39 PM
mynameizstitch
10
Aug 30, 2007 08:15 PM
turbo gsr
Jul 9, 2006 01:14 PM
HX_Guy
May 30, 2002 06:18 PM
