95 civic hatch won't crank
Old Jun 17, 2010 | 03:40 PM
zachrikature's Avatar
Default 95 civic hatch won't crank
I have an eg hatch, it won't crank. All of the dash lights come on like usual, fuel pump primes, but it won't crank. I checked all of the wires and everthing seems to be in place. Help?
Old Jun 17, 2010 | 05:21 PM
Former User's Avatar
Default Re: 95 civic hatch won't crank
1) Can you push start the engine?
2) Has the rubber stopper that presses on the safety starter switch at the top of the clutch pedal fallen out or broken?
3) If the rubber stopper is fine, unplug the switch 2P connector and short it with a jumper wire. Does the engine now crank?
4) If 1-3 are fine, wire the starter directly to the battery. If it does not crank, replace the starter.
Old Jun 17, 2010 | 05:25 PM
Silver04RS's Avatar
2) Has the rubber stopper that presses of the safety starter switch at the top of the clutch pedal fallen out or broken?
well said
Old Jun 17, 2010 | 05:53 PM
xTomei's Avatar
Exactly what he said. If you hear noise coming from the engine bay, like a grinding noise, your starter is loose which will make your car not start. Theres alot of things that can make it not fire up, but just do what the smart guy said. Ignore my nonsense
Old Jun 17, 2010 | 06:55 PM
I have two questions. I'm sorry but I am still very inexperienced with electrical stuff. Where is the 2P connector? and how exactly do I use a "jumper wire?"
Old Jun 17, 2010 | 07:23 PM
Unplug the connector for the switch and then insert a short wire or paperclip into the wire harness connector to short the two terminals.
Old Jul 26, 2010 | 09:29 AM
EJ6-2nr's Avatar
did you get this figured out Zach? if not gimme a shout i might be able to come out and take a look at it
Old Jul 26, 2010 | 09:30 AM
Thanks for all the help, it turned out to be my starter relay. I got that put in and she started right up.
Old Jul 26, 2010 | 09:33 AM
EJ6-2nr's Avatar
sweet deal, so whats you schedule like, wanna do that photoshoot i mentioned, weekends are good for me
Old Jul 26, 2010 | 09:37 AM
I'm free pretty much all the time. I just have to get my plates transferred off my old car to the hatch so I can drive it.
Old Jul 26, 2010 | 09:40 AM
EJ6-2nr's Avatar
u think that will happen this week?
jk-turbo-ef
Oct 16, 2015 11:10 AM
kris9
10
May 27, 2013 03:35 PM
frogg5872
Jun 23, 2010 10:45 AM
rick_rabies
26
Apr 5, 2009 01:07 PM
SOKal
Nov 13, 2006 10:14 AM
