how to solve this crappy problem
i drive civic sedan eg8, today my stereo died along with my car clock, why does this happen? i think its the fuse burned im i right? if not please do tell me cuz its bloody bored to death with the silent in my ride..
and my rear right door cant be open from inside and outside ...dohh why this silly things happens to me?? how should i fix this? do i have to remove the door handle from outside? im blurred now
I think the door handles can be remove from the inside by taking off the door panel. FOr the h/u you might want to check all wire under the dash and fuses for burn..
It is the "back-up" fuse in the engine bay fuse box, probably a 7.5A, it blows if you have an aftermarket HU with the HU 12V constant, [yellow] wired to the stock 12V constant in the radio harness.
You will need to run a fuse 12ga lead from the batt. to behind the HU, connect the HUs yellow lead to it, don't forget to cap off the stock 12V constant and replace the fuse, with the proper one, NEVER replace a fuse with a bigger one, you can burn your car to the ground. 94
i never knew about this fuse i had checked all the inside ones with no luck was going to just bite the bullet and replace both the clock and the hu
