obd2b motor for my obd1 da teg (i seached!)
Old Jun 17, 2010 | 08:56 AM
tougetuned_ef's Avatar
Default obd2b motor for my obd1 da teg (i seached!)
im trying to talk my brother into giving my his b16 out of his wrecked em1 si. i need to know what i will need to do to convert it to obd1. i have a wiring harness from an eg civic with vtec so i wont have to run the wires for vtec, but do i need to swap over the sensors and stuff on the motor? i curently have a b18a in the car half taken apart so can i use the sensors from that motor to run the b16. i also have a non-working obd1 b16 ecu that i was going to send out to be fixed. what do i need to buy/aquire for this swap? should i just run his obd2 ecu ut of his car and buy a conversion harness
Old Jun 17, 2010 | 09:57 AM
mtber's Avatar
Default Re: obd2b motor for my obd1 da teg (i seached!)
Run the obd2b motor on an obd1 ecu. Keep the engine harness that is in the vehicle already & modify the necessary plugs for the obd2 distributor, injectors & alternator etc.
Old Jun 17, 2010 | 01:51 PM
kool thanks
Mitcteba1124
Mar 25, 2015 09:24 AM
jamelin
Oct 10, 2009 04:53 PM
h22HatchEG
Apr 12, 2006 04:42 AM
pearl
Jun 11, 2005 04:10 AM
CivicSI1018
Aug 8, 2004 09:46 PM
