Viper 350plus starter kill relay wiring problems help
k i have a 97 honda civic hatch and i just finish installing my alarm myself everything went good but im lost on where to wire in the green and blk wire coming from the start kill relay provided from viper. i tried to wire it like this: green - blk/ylw ignition and blk - blk/whte to starter? but car starts even after arming so relay isnt wire correctly? plz help guys thanks.
You need to cut the starter wire, [black/white] and install the starter cut relay in between.
How many leads on the "Viper" relay?
It should be wired like this... http://www.the12volt.com/relays/page2.asp "normally closed starter kill relay" 94
Fcm to the rescue!!! Thanks for the response. i cut the wire in half (blk/white) now my real question is what side does the fat green wire on the relay go to?
Would it be connected to the key side or the other side going towards the fuse box?
Also what do u mean by leads? how many wires come from it (relay)? if so, it has a yellow wire which i guessing is the 12v constant? and a orange which loops back into the harness. and of course the green wure and blk wire.
k thanx man one more thing is it ok to have my yellow wire coming from the relay connected to the blk/yellow ignition wire it seems the alarm only works when its connected there? i tried puttting it at the white 12v and alarm doesnt turn on? well i will be putting those other wires how u told me and come back and let u kno if they work
tUnz_on
27
Oct 19, 2011 03:35 PM
delsolo95
Audio / Security / Video
23
Nov 8, 2010 08:13 PM
