Random Check engine light
So i get a CEL after driving for a while, like 30 min or so. but if i turn the car off then back on the CEL is gone for about 20-30 min, occasionally 10 min.
i pulled a code using a paper clip and i got code 1.
so i then changed out my o2 sensor. reset my ecu drove for a while. and BAM! the CEL is back. any ideas?
car is a 92 vx. with a d15b7. the engine harness is a ls harness.
now this could be a big issue. the o2 sensor is on the cat. should i plug the hole for the cat and run the plug to the header?
ok so i did all that and used a o2 sensor from my buddys car. so its for sure a working one. im still having the issue. im geting code 41 now. not code 1. im lost. my idle goes up and down. any ideas?
EJ8_Enthusiast
Sep 16, 2008 03:55 PM
pa_itr
Aug 8, 2005 07:48 PM
jdmb16ahybrid
Mar 19, 2003 03:07 PM
