Civic rear disc conversion
Old Jun 13, 2010 | 07:43 PM
Andrew14's Avatar
Default Civic rear disc conversion
When doing the civic rear disc conversion do you have to get an alignment after installation. Help please!
Old Jun 13, 2010 | 07:47 PM
xXViperXx's Avatar
Default Re: Civic rear disc conversion
Yes you will.
Old Jun 13, 2010 | 09:39 PM
MaK503's Avatar
not true. i had mine put on went to get an alignment and turns out i didnt need one. wouldnt hurt to go get one though.
Old Jun 14, 2010 | 12:16 AM
95civtecex's Avatar
I always get an alignment done when ever I remove/replace anything concerning the suspension cause tires aren't cheap an could possibly mess something up down the road
Old Jun 14, 2010 | 07:27 AM
scuzz's Avatar
Amen, the last one I changed out was so far out, the car drove awful till I got it to alignment shop.
Old Jun 14, 2010 | 07:37 AM
Andrew14's Avatar
ok, Thanks. Also is this a cause why my driver side back wheel always goes down after i adjust the coilover up.
Old Jun 14, 2010 | 07:39 AM
speedooo's Avatar
All of this he said she said bullshit needs to stop.
Nobody cares if you did or didn't get an alignment, so don't reply with YES YOU NEED IT or NO MY ALIGNMENT WAS FINE!
The bottom line is that you will be removing the rear trailing arm thus upsetting your current alignment. You do no need an alignment, nobody really does, but getting one will make you car handle better, your tires will last longer and your car will drive straight.
Old Jun 14, 2010 | 08:17 AM
Andrew14's Avatar
you don't have to hate man!! Just answer the question and if you have nothing good to say, just don't say nothing.
Old Jun 14, 2010 | 08:57 AM
98civdx's Avatar
Master Detailer
Don't removeb the toe componsator from the car!, un-bolt from trailing arm. This way the alignment doesn't change.
It wouldn't hurt to get one, but isn't required if you unbolt that arm from car
Old Jun 14, 2010 | 09:27 AM
Andrew14's Avatar
oh, ok i removed it already when i did the conversion so i basically need an alignment. Thanks again!!
Chris Crane
Nov 12, 2008 07:57 PM
Ex Member
Aug 3, 2006 12:00 PM
eghatchproject
Jan 17, 2004 06:14 PM
MokujinX5
Dec 16, 2003 02:50 PM
